Joined: Mon Feb 21, 2011 3:21 am Posts: 563 Location: NSW
Posted: Fri Jul 20, 2012 7:10 am
Hey all, Going to the wreckers on the weekend and i need some hslp picking out the difference between the nt and wt diff, just in case the wrecker guy tells me the wrong thing cheers
Centres: NT & WT look identical except for the drive flange. NT has 8mm holes.... WT has 10mm holes.
Housings: Front; NT front has the drivers side perch halfway up the rounded part of the pumpkin. WT has the drivers side perch on the flat of the axle tube.
Housings: Rear; NT has no provision for handbrake in the drums also has no handbrake cable mounts across the axle tubes. WT does have handbrake in the drums and has cable mounting lugs.
Users browsing this forum: Google [Bot] and 257 guests
