It is currently Tue Nov 03, 2026 5:21 pm
Post Posted: Thu Jul 19, 2012 1:27 pm
What should I put in the rear of my swb tintop mini spool or a spartan locker?
It's only used for weekend wheeling so I dont care about tyre wear.
Is the extra money worth putting in a spartan over a mini spool?
Vehicle: 4wd
Post Posted: Thu Jul 19, 2012 1:52 pm
Spool.
No.
Watch out or you'll get sued.
Post Posted: Thu Jul 19, 2012 2:03 pm
stockman wrote:
Spool.
No.
From experience or second hand information?
Vehicle: 2018 DMAX
Post Posted: Thu Jul 19, 2012 2:59 pm
Spool it. Dont waste money on an autolocker.
Vehicle: 4wd
Post Posted: Thu Jul 19, 2012 3:18 pm
dono1 wrote:
stockman wrote:
Spool.
No.
Experience.
Post Posted: Thu Jul 19, 2012 4:19 pm
Spooooooooooooooooool so much nicer, and chicks dig tyre churp ;)
tintop, barwork, locked Front , RUF, 4.9's, 31's :
Post Posted: Thu Jul 19, 2012 4:30 pm
i have to disagree with the tyre chirp thing cause my missus hates it but indefinably spool. so much more predictable
Post Posted: Thu Jul 19, 2012 5:16 pm
spool rear
spartan front
Ran my Sierra that way for many years.
Post Posted: Thu Jul 19, 2012 6:38 pm
Spool..
You'll get used to it soon enough. Go easy till you do though...
Understeer in... Oversteer through and understeer out of corners... Keeps you awake... :D
The effects are less exaggerated on road if you have VERY chunky mud tyres EG centipedes or Silverstones.
Post Posted: Thu Jul 19, 2012 6:51 pm
good point, road based tyres suck with spools
Post Posted: Thu Jul 19, 2012 7:19 pm
Weld if you're going the spool option IMO
Post Posted: Thu Jul 19, 2012 7:25 pm
na,spool before welded.
worth minimal money and more reliable
Post Posted: Thu Jul 19, 2012 7:30 pm
I ran a shimmed up lsd in my patrol it was fully locked and used to chirp when cornering or parking! I didnt mind it but yeh the missus hated it!
Is it worth gettin a spool or just weld it if its not my daily?
Post Posted: Thu Jul 19, 2012 9:00 pm
SPOOL...
Spool is removable.
Welded is not removable. It ruins a set of spider gears and is prone to failure.
Post Posted: Thu Jul 19, 2012 9:04 pm
Cheaper if you weld it good. never had a problem or even a crack in my welded centre.
Post Posted: Thu Jul 19, 2012 9:07 pm
Yes I highly agree, spool.
I ran a welded rear for a long time, as back then nothing was available.
1 disintegrated after a couple of years, but the 2nd lasted a very long time.
A spool is dirt cheap, and no heat stress to delicate parts.
Vehicle: 2004 SQ625 GV
Post Posted: Thu Jul 19, 2012 9:24 pm
A WELL setup auto locker is a good option. Very predictable IMO.
Vehicle: 1999 Jimny
Post Posted: Fri Jul 20, 2012 5:41 am
Gotta agree, If a locker is set up correctly you shouldn't have a drama on the street at all.
Post Posted: Fri Jul 20, 2012 6:31 am
X2 auto lockers are barely noticeable when setup properly.
Vehicle: 2018 DMAX
Post Posted: Fri Jul 20, 2012 9:01 am
But he is not using it for street purposes going by his first post, so were back to the Spool....
Gives the option of returning to an open center if needed with little fuss.
Vehicle: 00 Jimny, 63 Haffy
Post Posted: Fri Jul 20, 2012 10:23 am
Im a fan of the Spartans, but if its not your DD, then Spool it.
If your doing the front, air lock it if you can. I had a spartan in the front but I also had put in PS which helped it be ok.
I had to let off up hills when I should have been under power in order to turn sometimes. Turning is better than crabbing.
Users browsing this forum: Google Adsense [Bot] and 453 guests
