It is currently Sun Nov 01, 2026 1:28 am
Post Posted: Sat Jul 21, 2012 10:31 am
Hi all,
I have a 94 LWB Vitara. While cornering to the left only, the hand brake warning light comes on under cornering loads. Never to the right. I would appear to be when fluids of some sort move away from a sensor, but I cant work out which ones!! Does anyone have any experience with this or any ideas where I can start looking?!!
Cheers Nick.
Vehicle: sierra
Post Posted: Sat Jul 21, 2012 11:00 am
brake master cylinder.
Post Posted: Sat Jul 21, 2012 11:01 am
^^^ this
it's a low fluid warning.
Vehicle: 91 WT 1.6EFI
Post Posted: Sat Jul 21, 2012 11:02 am
Have you checked the brake fluid? It it's low it would set the sensor off when cornering
Post Posted: Sat Jul 21, 2012 12:00 pm
Thnx guys. I will look into that.
Post Posted: Sat Jul 21, 2012 2:25 pm
nicktoozoff wrote:
Hi all,
Cheers Nick.
Does the Vitara use fluid in the hand brake ??
Sounds like its just a crappy switch.
Vehicle: sierra
Post Posted: Sat Jul 21, 2012 2:33 pm
the same light came on in the mrs vit when the fluid was low, same with sierra, the park light stays on
SuziBlu wrote:
nicktoozoff wrote:
Hi all,
Cheers Nick.
no but it uses the handbrake warning light as a low brake fluid level warning. :wink:
if it was a french build shitbox, i'd believe it if it was a fluid powered handbrake... checked the oil on the C4 Citroen i'm driving & the dipstick is literally a piece of wire with a pissy plastic handle & a plastic end on it with the E & F marks on it.
Post Posted: Sat Jul 21, 2012 4:53 pm
Lots of cars/trucks use a wire dipstick because of the convoluted path they take from the top to the sump.
Normal flat steel only bends in one plain.
Post Posted: Sun Jul 22, 2012 1:57 pm
Yeah the master brake cylinder was way low on brake fluid. Topped up, no more warning light!! Thnx guys!!
Post Posted: Sun Jul 22, 2012 2:17 pm
now you need to find the leak that caused the low fluid level.
Users browsing this forum: No registered users and 450 guests
