It is currently Sat Oct 17, 2026 4:48 pm
Post Posted: Sun Jul 22, 2012 2:20 pm
Hi All,
Back again. I am running 30" Nexen AT II's on my unlifted Vit. With a load in the back or at speed the rear shocks are compressing enough that the tyres are rubbing up inside the rear wheel arches. Can I put in a set of HD rear shocks to compensate for this or will coils be required as well? If funds allow I am looking at fitting a 35mm suspension lift upgrade, but for now I was wondering if heavier duty shocks will fix problem.
Cheers Nick.
Post Posted: Sun Jul 22, 2012 2:28 pm
No, sorry shox wont help.
A shock only stops the car from continuous bouncing.
You need a stiffer spring, or a longer spring, or a spring spacer.
Or a longer bump stop, so tyre can't come up so far.
Wait till you get your lift in, it may be fine after that.
Post Posted: Sun Jul 22, 2012 2:32 pm
Thnx! I'll save the dollars for the shocks and put it too a complete kit. Any ideas on something middle of the road, not too exxy not cheap crap!! Only want to do coils and struts, about 30-40mm lift.
Post Posted: Sun Jul 22, 2012 2:44 pm
Talk to Dank. In my opinion Dobinsons is good value, and Dank is a forum member we trust..
http://auszookers.com/forum/viewtopic.php?f=15&t=20219
http://auszookers.com/forum/memberlist. ... file&u=387
Vehicle: 93 vitara estate
Post Posted: Tue Jul 31, 2012 6:23 pm
hi
i put a 1 inch lift in mine only caz i got it for $100 .any how i also run 30x 9.5 maxxis and have no issues scrubbing out not even at full lock.
personally if i was doing it again tho i would go a 2 inch lift
Post Posted: Tue Jul 31, 2012 7:14 pm
Its just about $1000 to get the dobinsons lift with cam boltsfrom KPD. well worth the money if you ask me.
Users browsing this forum: Google [Bot] and 263 guests
