http://auszookers.com/forum/
HD rear shocks for LWB Vitara
http://auszookers.com/forum/viewtopic.php?f=5&t=34390
Author:  nicktoozoff [ Sun Jul 22, 2012 2:20 pm ]
Post subject:  HD rear shocks for LWB Vitara
Hi All,
Back again. I am running 30" Nexen AT II's on my unlifted Vit. With a load in the back or at speed the rear shocks are compressing enough that the tyres are rubbing up inside the rear wheel arches. Can I put in a set of HD rear shocks to compensate for this or will coils be required as well? If funds allow I am looking at fitting a 35mm suspension lift upgrade, but for now I was wondering if heavier duty shocks will fix problem.
Cheers Nick.
Author:  christover1 [ Sun Jul 22, 2012 2:28 pm ]
Post subject:  Re: HD rear shocks for LWB Vitara
No, sorry shox wont help.
A shock only stops the car from continuous bouncing.
You need a stiffer spring, or a longer spring, or a spring spacer.
Or a longer bump stop, so tyre can't come up so far.
Wait till you get your lift in, it may be fine after that.
Author:  nicktoozoff [ Sun Jul 22, 2012 2:32 pm ]
Thnx! I'll save the dollars for the shocks and put it too a complete kit. Any ideas on something middle of the road, not too exxy not cheap crap!! Only want to do coils and struts, about 30-40mm lift.
Author:  christover1 [ Sun Jul 22, 2012 2:44 pm ]
Talk to Dank. In my opinion Dobinsons is good value, and Dank is a forum member we trust..
http://auszookers.com/forum/viewtopic.php?f=15&t=20219
http://auszookers.com/forum/memberlist. ... file&u=387
Author:  tsock0 [ Tue Jul 31, 2012 6:23 pm ]
hi
i put a 1 inch lift in mine only caz i got it for $100 .any how i also run 30x 9.5 maxxis and have no issues scrubbing out not even at full lock.
personally if i was doing it again tho i would go a 2 inch lift
Author:  Built4thrashing [ Tue Jul 31, 2012 7:14 pm ]
Its just about $1000 to get the dobinsons lift with cam boltsfrom KPD. well worth the money if you ask me.
