| Author |
Message |
stocker
Joined: Wed Dec 08, 2010 7:16 am Posts: 941 Location: Shidoni!
 Posted: Tue Jul 24, 2012 8:36 pm |
Help me sierra owners!!! What diff ratio's are available for a Sierra, i need teeth count as well I need something with a tooth count on the crown wheel of around 45
_________________ Stocker
atari4x4
 Posted: Tue Jul 24, 2012 8:50 pm |
i think it's a no go in the suzuki range, somewhere on here is a list of tooth counts
stocker
 Posted: Tue Jul 24, 2012 9:24 pm |
Thanks Atari... I found the vitara one in 'good tech' after searching for a bit but I cant find one for sierras...
atari4x4
 Posted: Tue Jul 24, 2012 9:35 pm |
i thought it had both.
303zuke
Vehicle: LJ50V, SJ70
 Posted: Tue Jul 24, 2012 10:49 pm |
stocker wrote: I need something with a tooth count on the crown wheel of around 45 Why that specific number of teeth? On a small ring gear like the Sierra, that many teeth will be fairly weak compared to other R&P sets with less teeth. AFAIK, thse are the ratios available for 1.3 Sierra diffs: 3.727= 41/11 (WT Sierra) 3.909= 43/11 (NT Sierra) 4.09= 45/11(Jimny) 4.11= 37/9 (WT Maruti) 4.3= 43/10 (GV front) 4.556= 41/9 (US Aftermarket) 4.625= 37/8 (Vit Auto front) 4.875= 39/8 (GV front) 5.125= 41/8 (Vit Manual front)
stocker
 Posted: Wed Jul 25, 2012 8:46 am |
Look I don't know much about what I'm proposing hence a bit of research
Could you perhaps combine 2 different sets of r&p and crown wheels together??
Ie: 8 tooth pinion out of my centre with a 43 tooth crown wheel from a gv???
BlueSuzy
 Posted: Wed Jul 25, 2012 9:25 am |
Pinion and crown are a matching gearset. They have to intertwine perfect. So mix/match ratio parts are a no go.
Different ratios gears will be a poofteenth different size, and makes lap timing different, hence, different ratios.
Just swap a whole set.
stocker
 Posted: Wed Jul 25, 2012 2:05 pm |
BlueSuzy wrote: Pinion and crown are a matching gearset. They have to intertwine perfect. So mix/match ratio parts are a no go.
Just swap a whole set. Thankyou well that answers my question. However the area i have highlighted is my problem... To What might I ask? I am already running a 5.125 - 1 ratio
tanshi
Joined: Tue Jan 09, 2007 10:30 pm Posts: 7717 Location: Brisbane
 Posted: Wed Jul 25, 2012 2:18 pm |
303zuke
 Posted: Wed Jul 25, 2012 10:17 pm |
stocker wrote: BlueSuzy wrote: Just swap a whole set. However the area i have highlighted is my problem... To What might I ask? I am already running a 5.125 - 1 ratio If you're already running 5.125 diffs in a Sierra and NEED to go lower, I'd be investigating Transfer Gearing.
stocker
 Posted: Thu Jul 26, 2012 11:45 pm |
transfer only effects low range mate, i need hi range re gearing...
i have approached a Diff company about a custom ring and pinion set for the rear. will wait to see what they come back with $$$ wise
BlueSuzy
 Posted: Thu Jul 26, 2012 11:53 pm |
stocker wrote: transfer only effects low range mate, i need hi range re gearing...
i have approached a Diff company about a custom ring and pinion set for the rear. will wait to see what they come back with $$$ wise Yeah your being confused in asking a sierra question, but owning a vitara(avatar)
tanshi
 Posted: Fri Jul 27, 2012 8:51 am |
look at an undertaker, will be cheeper than custom diffs
stocker
 Posted: Fri Jul 27, 2012 11:43 am |
BlueSuzy wrote: stocker wrote: transfer only effects low range mate, i need hi range re gearing...
i have approached a Diff company about a custom ring and pinion set for the rear. will wait to see what they come back with $$$ wise Yeah your being confused in asking a sierra question, but owning a vitara(avatar) No I am not mistaken in asking what ratios are available for a sierra as a bit front is the same as a sierra rear this would then only require a custom vitara rear to be manufactured. We will see when I get a quote back
zooker
Joined: Sun Aug 06, 2006 11:30 pm Posts: 596 Location: Queanbeyan
 Posted: Fri Jul 27, 2012 5:39 pm |
edit, misread the car he actually has
_________________ Member of C.O.R 4x4
atari4x4
 Posted: Fri Jul 27, 2012 5:46 pm |
 gus is confused  custom width sierra front diff with a new custom longer short side hi-tuff axle + chromos = SAS VIT?
TZAR
Joined: Tue Aug 01, 2006 11:30 pm Posts: 3461 Location: licking some windows
Vehicle: LJ20 LJ50
 Posted: Fri Jul 27, 2012 5:58 pm |
so its too fast in high range????
Custom Diffs = Equals bubba ramming his cock up your arse at high speed = getting reamed good
Why not look at different diffs if you want more reduction IE hilux 5.88 cheaper than custom and MUCH easier to replace if needed
_________________ Camels have nice toes
stocker
 Posted: Fri Jul 27, 2012 6:08 pm |
oooooooooooookayyy...
No gus no solid axle swapsies...
The idea was that i could correct the Spastic gearing i have at the moment. Currently 5.125 on 31's Is horrid... there is no such thing as 5th gear on anything other than down hill. and driving in 4th everywhere means your revving the tits out of it on the express ways.
...So my thoughts were. Replace the Front R&P with a commonly available sierra R&P Set. Now as we are all aware higher ratio R&P sets are few and far between for the Vits. So i would get a Custom R&P Set manufactured to suit the Commonly available Sierra R&P say like the 5.38 Set that LROR sell to correct my horrible gearing. Now obviously i have to do a few calculations to find out exactly how high i will have to go to get as close to driving like stock as possible.
...Well thats my idea anyway...
TZAR
Vehicle: LJ20 LJ50
 Posted: Fri Jul 27, 2012 6:45 pm |
What about adding a sierra transfer case and getting higher diff ratios
Vitarad is 1.1 high range/ something lowrange Sierra is 1.4 high range/ 2.2 low range
This would give you a choice of HH HL LH LL.
This si a guanausteve one to answer as this sort of question is right up his alley.
303zuke
 Posted: Fri Jul 27, 2012 10:50 pm |
stocker wrote: The idea was that i could correct the Spastic gearing i have at the moment. Currently 5.125 on 31's Is horrid... there is no such thing as 5th gear on anything other than down hill. and driving in 4th everywhere means your revving the tits out of it on the express ways.
...So my thoughts were. Replace the Front R&P with a commonly available sierra R&P Set. Now as we are all aware higher ratio R&P sets are few and far between for the Vits. So i would get a Custom R&P Set manufactured to suit the Commonly available Sierra R&P say like the 5.38 Set that LROR sell to correct my horrible gearing. Now obviously i have to do a few calculations to find out exactly how high i will have to go to get as close to driving like stock as possible. Well, now that you've explained yourself better.... 5.38s probably won't help you. The difference between 5.125 and 5.375 gearing is LESS THAN 5%. That is 50rpm per 1000. So if your doing 6000rpm in 4th now, an exxy custom made rear diff in 5.38 ratio will bring your revs down to 5700rpm. Worth the cost? A more cost effective solution would be either an Undertaker transfer, or completely new Dana diffs F + R in a significantly lower ratio like 6.17.
twitchy
Joined: Fri Jul 25, 2008 11:30 pm Posts: 1086 Location: Lightning Ridge
Vehicle: 1999 Jimny
 Posted: Sat Jul 28, 2012 8:21 am |
If the sierra is in Ipswich, Tasmania or Cullen Bullen I'd say the diff would have about 3 teeth.....
sideways
Joined: Fri Oct 29, 2010 1:53 pm Posts: 5944 Location: Northcliffe, W.A.
 Posted: Sat Jul 28, 2012 9:22 am |
stocker
 Posted: Mon Jul 30, 2012 9:09 pm |
sideways wrote: You need a set of these. 1.3:1 reduction and more awesomeness than an Vitara can Handle. viewtopic.php?f=14&t=4251&start=390Will be cheaper than a custom R&P too.  that would be awesome! but engineering? Some more food for thought over the last few days. How do the XL7 Diff's hold up to 31's (that is the Non-steel versions)???
