| dent above sills http://auszookers.com/forum/viewtopic.php?f=5&t=34505 |
| Author: | Jfuit94 [ Thu Jul 26, 2012 8:36 pm ] |
| Post subject: | dent above sills |
i have a dent that goes from the front of the passenger side sills to the rear, and up behind the door. if i cut the sill out am i going to be able to get my hand up in behind it the pop it back out??????/ considering half the dent would be gone should pop out pretty easy |
| Author: | Fatzook [ Thu Jul 26, 2012 10:08 pm ] |
| Post subject: | Re: dent above sills |
Jfuit94 wrote: i have a dent that goes from the front of the passenger side sills to the rear, and up behind the door. if i cut the sill out am i going to be able to get my hand up in behind it the pop it back out??????/ considering half the dent would be gone should pop out pretty easy Only way you are going to get any sort of reliable answer is to post up some pics mate. |
| Author: | Jfuit94 [ Fri Jul 27, 2012 8:11 pm ] |
yeah havent got any at present that are any good. try to take some tomorow |
| Author: | Red89 [ Fri Jul 27, 2012 9:07 pm ] |
If I have read it right, if you cut your sills like this you will be able to reach up inside the B pillar, there is a small piece of metal joining the inner and outer skin of the b pillar about 4 inches up from were I cut the sill and depending on the size and type of dent you may not get enough leverage to push the dent out by hand. If you remove the seatbelt retraction part from the inside of the pillar you may reach it using a hammer and block of wood if its further up the pillar.
| Author: | Jfuit94 [ Sat Jul 28, 2012 3:37 pm ] |
i tried uploading a photo but it says it too big. the dent runs along the sill then behind the door it gos up about 100 - 150mm or so |
| Author: | suzukikid [ Sat Jul 28, 2012 4:43 pm ] |
just leave it....chicks dig body damage |
| Author: | KEENSY85 [ Sun Jul 29, 2012 7:57 pm ] |
just cover in ali |
| Author: | Joshyboy26 [ Sun Jul 29, 2012 8:36 pm ] |
Please dont. |
| Author: | Fatzook [ Sun Jul 29, 2012 9:52 pm ] |
KEENSY85 wrote: just cover in ali Please be joking
| Author: | suzukikid [ Mon Jul 30, 2012 8:17 am ] |
im hopin thats a joke too....... |
| Author: | Jfuit94 [ Thu Aug 02, 2012 8:28 pm ] |
had thought about the old checker plate fix it |
| Author: | got_bar_work [ Fri Aug 03, 2012 4:34 am ] |
Jfuit94 wrote: had thought about the old checker plate cover up the rust behind it
