It is currently Mon Oct 19, 2026 12:06 am
Vehicle: Sierra SJ70
Post Posted: Mon Jul 30, 2012 7:25 am
Just wondering what you guys have done with your radiator when putting in a G16 engine into your sierra. My fan is only millimeters away from hitting the pulleys.
Vehicle: SJ51T
Post Posted: Mon Jul 30, 2012 8:49 am
What fan are you using? If its the sierra one do you have the spacer fitted?
Post Posted: Mon Jul 30, 2012 8:34 pm
i have a thermo fan as u can see below. it just clears the pulleys but not by enough i would assume. do you reckon i could just put a spacer/washer over the 4 bolts that hold the radiator to the radiator bracket which would push the radiator further away from the pulleys? would that be enough?
Post Posted: Mon Jul 30, 2012 9:18 pm
Put the spacers between the rad and the uprights to space the whole thing forward. You may need to rebend or remove the bonnet prop stick so it doesn't rub on the top tank...
Post Posted: Tue Jul 31, 2012 8:00 am
yeah thanks, thats what i was thinking. ill just take the bonnet stick off coz i dont need it.
Users browsing this forum: No registered users and 519 guests
