| Toyota 4age engine into swb VIT Q's http://auszookers.com/forum/viewtopic.php?f=5&t=34608 |
| Author: | Samwich [ Tue Jul 31, 2012 11:39 am ] |
| Post subject: | Toyota 4age engine into swb VIT Q's |
So im thinking about popping a Toyota 4age engine in my Vit... 1. has this been done 2. how hard 3. Is it worth it 4. Your thoughts??? |
| Author: | BlueSuzy [ Tue Jul 31, 2012 11:50 am ] |
| Post subject: | Re: Toyota 4age engine into swb VIT Q's |
Not worth it for a 1.6 injected vit already. Id look into a J20 or H20/25/27 |
| Author: | Samwich [ Tue Jul 31, 2012 11:55 am ] |
BlueSuzy wrote: Not worth it for a 1.6 injected vit already. Id look into a J20 or H20/25/27 Why wouldnt it be?? haha J20 = 109 hp.... this 4age = 130hp (stock) |
| Author: | ninjamoses [ Tue Jul 31, 2012 12:15 pm ] |
Not sure where you are getting your figures from but they are wrong. J20A vits have ~96kw (ie. 130hp). Pretty sure no 4A-GE came close to that, checking wiki shows even the highest output 'red top' version only had 94kw. Either way, considering a healthy G16B is meant to put out mid 70kw I don't think it'd be worth the effort. If you are going to the trouble of an engine conversion may as well do it properly and go with a H25A or similar. If the stock motor is healthy just throw on some extractors/exhaust and enjoy thashing it? EDIT: 20 valve 4A-GE does put out those figures and more, but still don't think its worth it unless the current engine is toast. Bet the price of 20 valves is through the roof also. |
| Author: | Liljim [ Tue Jul 31, 2012 12:53 pm ] |
I wouldn't bother, They might have the HP, but 4AGs are not very torquey, they make most of their power after 5000 revs, not exactly what you want for 4x4ing. The 20 valves are even less flexible down low in the revs, and they feel really lethargic down low, even in a corolla. |
| Author: | Samwich [ Tue Jul 31, 2012 12:57 pm ] |
ninjamoses wrote: Not sure where you are getting your figures from but they are wrong. J20A vits have ~96kw (ie. 130hp). Pretty sure no 4A-GE came close to that, checking wiki shows even the highest output 'red top' version only had 94kw. Either way, considering a healthy G16B is meant to put out mid 70kw I don't think it'd be worth the effort. If you are going to the trouble of an engine conversion may as well do it properly and go with a H25A or similar. If the stock motor is healthy just throw on some extractors/exhaust and enjoy thashing it? EDIT: 20 valve 4A-GE does put out those figures and more, but still don't think its worth it unless the current engine is toast. Bet the price of 20 valves is through the roof also. Thanks for the info, How easy are the H25A or the J20A's to install?? |
| Author: | suzkboy [ Tue Jul 31, 2012 1:31 pm ] |
Ae92 4age smallport was 100kw and its one of the more common available |
| Author: | tanshi [ Tue Jul 31, 2012 1:33 pm ] |
its also a cast iron block isnt it. J20A will be less work than an AGE |
| Author: | buzbox [ Tue Jul 31, 2012 1:34 pm ] |
Torque and power band low in the rev range is what you want for offroad, A G16b would be a realitivly straight swap in your Vit, or as other's have suggested the J20. The 4AGE in my craparolla starts moving at 3500rpm, down low, it's shite. |
| Author: | suzkboy [ Tue Jul 31, 2012 1:37 pm ] |
The low down tourqe in my 4age corolla is a lot better than my m18 in my jimmy anyday but for ease of transplant keep it Suzuki |
| Author: | DarkHorse [ Tue Jul 31, 2012 2:39 pm ] |
ninjamoses wrote: If you are going to the trouble of an engine conversion may as well do it properly and go with a 1UZ-FE or an LS9. Fixed. |
| Author: | stocker [ Wed Aug 01, 2012 2:53 pm ] |
DarkHorse wrote: ninjamoses wrote: If you are going to the trouble of an engine conversion may as well do it properly and go with a 1UZ-FE or an LS9. Fixed. x 2 426 Hemi? |
| Author: | KEENSY85 [ Wed Aug 01, 2012 7:03 pm ] |
arnt 4age 's got a lot more performance opertunites and u can a quad throttle body version as well |
| Author: | BRAD [ Wed Aug 01, 2012 8:10 pm ] |
stocker wrote: DarkHorse wrote: ninjamoses wrote: If you are going to the trouble of an engine conversion may as well do it properly and go with a 1UZ-FE or an LS9. Fixed. x 2 426 Hemi? or one of these http://www.youtube.com/watch?v=fzJSNFWiHeE |
| Author: | KEENSY85 [ Wed Aug 01, 2012 8:16 pm ] |
holy shit
