| manual box to auto box vitara help? http://auszookers.com/forum/viewtopic.php?f=5&t=34643 |
| Author: | BRAD [ Wed Aug 01, 2012 6:44 pm ] |
| Post subject: | manual box to auto box vitara help? |
hey all, so ive got a 92 swb vitara 1.6l g16a manual and i think its about time to get a re-con gearbox ,the one ive got makes all the weird noises especially in 5th gear but i thought mabye putting an auto box into it? just wondering if anyone knows if ill have to change anything other than the box,gear stick and tranny cooler? Cheers |
| Author: | stocker [ Wed Aug 01, 2012 8:04 pm ] |
| Post subject: | Re: manual box to auto box vitara help? |
pretty sure the auto needs an ECU to control it also... perhaps someone with a bit more knowledge than me can help...??? atari maybe??? |
| Author: | mnemonix [ Wed Aug 01, 2012 8:31 pm ] |
Carby vitara, whack in a 3spd auto. Call it a day. |
| Author: | BRAD [ Wed Aug 01, 2012 8:48 pm ] |
cheers stocker yeah forgot about that mnemonix wrote: Carby vitara, whack in a 3spd auto. Call it a day. haha i wish it was that easy |
| Author: | Vits93 [ Wed Aug 01, 2012 8:59 pm ] |
BRAD wrote: cheers stocker yeah forgot about that mnemonix wrote: Carby vitara, whack in a 3spd auto. Call it a day. haha i wish it was that easy Quote from another post "The 3 Speed (trimatic) is vacuum/thottle cable shifted No electronics" so maybe peddle box and vacuum lines to be changed and installed. |
| Author: | BRAD [ Wed Aug 01, 2012 9:06 pm ] |
didnt know that thanks so would you know where the peddle box goes ? im asuming underneath the dash on top of the pedal arm or not? do the vitaras come out with a 4speed auto? and would anyone know what the auto 3speed is like in low range? |
| Author: | BRAD [ Wed Aug 01, 2012 9:10 pm ] |
sorry what a stupid question of course they come out 4 speed haha :L |
| Author: | Vits93 [ Wed Aug 01, 2012 9:11 pm ] |
BRAD wrote: didnt know that thanks so would you know where the peddle box goes ? im asuming underneath the dash on top of the pedal arm or not? do the vitaras come out with a 4speed auto? and would anyone know what the auto 3speed is like in low range? i think you can just remove the clutch peddle and change to a auto brake peddle and the box is above the steering shaft. The 4 speed is for EFI only as it uses a computer which also sends a signal to the ECU. |
| Author: | BRAD [ Wed Aug 01, 2012 9:24 pm ] |
cheers vits93 would anyone be able to post up pics of there gear box in your spare time? |
| Author: | Fatzook [ Wed Aug 01, 2012 10:55 pm ] |
I have a low kms 4sp with T-bar, pedal box, TCM and TCM loom section for sale. The convertor comes with it, but You'll need a flex plate. |
| Author: | got_bar_work [ Thu Aug 02, 2012 3:44 am ] |
Isnt the cross members different as well because the auto is longer or somethink |
| Author: | BRAD [ Thu Aug 02, 2012 6:06 pm ] |
Fatzook wrote: I have a low kms 4sp with T-bar, pedal box, TCM and TCM loom section for sale. The convertor comes with it, but You'll need a flex plate. ill keep that in mind just gonna go to the wreckers first and go throught what i have to get and where everything is placed thanks got_bar_work wrote: Isnt the cross members different as well because the auto is longer or somethink mabye not sure |
| Author: | atari4x4 [ Thu Aug 02, 2012 6:09 pm ] |
rear tailshafts are different on the 4 speed auto/manual... not sure about the 3 speed but i'd say they'll be different. |
| Author: | rustyzook [ Thu Aug 02, 2012 6:18 pm ] |
BRAD wrote: and would anyone know what the auto 3speed is like in low range? pretty good, the auto takes up the slack. |
| Author: | Vits93 [ Thu Aug 02, 2012 6:33 pm ] |
got_bar_work wrote: Isnt the cross members different as well because the auto is longer or somethink Auto has a bracket for the exhaust to bolt to other than that they are the same, but there is a support that bolts to the cross member and the chassis on the r/h side which the torque stopper Bush bolts to. |
