| Belt wrap on engine pulleys http://auszookers.com/forum/viewtopic.php?f=5&t=3467 |
| Author: | Damo [ Wed Dec 03, 2008 3:15 am ] |
| Post subject: | Belt wrap on engine pulleys |
This is a split topic. The post you are reading refers to this post You might not have enough belt wrap around the A/C pulley, it's prolly gonna slip on that under load. You might be able to put a little idler in between the A/C pump and the P/S pump if you have problems. |
| Author: | jimbo_jones [ Wed Dec 03, 2008 4:02 am ] |
| Post subject: | Re: a zook on 37's |
Damo wrote: You might not have enough belt wrap around the A/C pulley, it's prolly gonna slip on that under load. You might be able to put a little idler in between the A/C pump and the P/S pump if you have problems.
thanks damo its a work in progress if it needs it I'll put one in |
| Author: | Damo [ Wed Dec 03, 2008 10:13 am ] |
jimbo_jones wrote: Damo wrote: You might not have enough belt wrap around the A/C pulley, it's prolly gonna slip on that under load. You might be able to put a little idler in between the A/C pump and the P/S pump if you have problems. thanks damo its a work in progress if it needs it I'll put one in Aren't they all Do you still want those shock towers? I PM'd you but the msg hasn't left my outbox yet. I got the towers boxed up ready to go. |
| Author: | Hybrid [ Wed Dec 03, 2008 1:05 pm ] |
Yeah the crank and power steer pulleys look ok but that AC compressor hasn't got anywhere near enough arc of contact. I think I have a link here on how to calculate how much you need if you want it. I found it when I was having the same supercharger dilemmas |
| Author: | Hybrid [ Wed Dec 03, 2008 1:06 pm ] |
Here it is anyway http://www.bacharach-training.com/norm/arc.htm |
