Since I just commented about tech in chat I figured I should try to contribute some tech to tech.
The below link gives calculations on how to determine the necessary arc of contact for a belt on multiple pulleys. This helps when running more than 2 pulleys to one belt. I found it when trying to determine if I could run the crank, powersteer and supercharger pulleys off the same belt without slippage. Hopefully its helpful for other people.
Users browsing this forum: No registered users and 275 guests
