It is currently Fri Oct 23, 2026 1:29 am
Post Posted: Fri Aug 03, 2012 3:51 pm
I have now stripped a front diff/axle housing to nothing.
Just looking at king pin bearings.
I was expecting ( never done king pin bearings before!) to be able to remove the outer race to the bearing.
They are wide track Diffs, the issue is the race, or lack of it. The bearing just sits in the taper?
Obviously which must get machined if damaged?
If there is a race there I'm blind!!
Is this right?
Thanks josh.
BTW. I did search and don't find anything specific. :oops:
Post Posted: Fri Aug 03, 2012 4:37 pm
When you buy new bearings you get we races which tap in/out of the knuckle.
Post Posted: Fri Aug 03, 2012 4:50 pm
Yeah I got the races with the bearings. But I couldn't see if there were a race in the housing. Quite rusty.
I'll give it a go tomorrow.
Thanks Dan.
Vehicle: 85 Suzuki Sierra
Post Posted: Fri Aug 03, 2012 5:05 pm
The race edges stick out of the housing, and are a different color metal. So they should be hard to miss if you give everything a good clean!
Got a pic of it now?, I'd be interested to see whats rusty.
Orange LWB Sierra
Post Posted: Fri Aug 03, 2012 5:21 pm
In the bare knuckle balls there will be a seat for it to sit in top and bottom
Post Posted: Fri Aug 03, 2012 5:33 pm
Yeah its all rusty!! Haha
Got it but. All good.
They were out in the weather for years with not much oil/Grease in them.
They were cheap. Real cheap. Other than this they look good. :)
Thanks fellas.
Users browsing this forum: Google [Bot] and 382 guests
