It is currently Thu Oct 22, 2026 9:19 pm
Vehicle: SJ51T
Post Posted: Fri Aug 03, 2012 6:00 pm
So I have noticed the revs fall when I press my foot on the brake and upon further investigation (pumping the brake) the engine dies down and stalls out comparitive to how much i pump the brake.
I assume this is a problem between the brake booster and the vaccum in the engine but this is where it gets beyond me.
ideas ?
Humble beginnings
Post Posted: Fri Aug 03, 2012 7:07 pm
Probably a split diaphragm in the booster.
Replace it or have it rebuilt.
Vehicle: 1985 Holden Drover
Post Posted: Fri Aug 03, 2012 7:29 pm
Carby 1.3?
1989 WT Sierra.
Post Posted: Fri Aug 03, 2012 8:00 pm
When I installed my G16a I had the same problem in my sierra. Quite annoying in a rally when you jump on the brakes and the cars stalls :lol: . To fix it I replaced all of the vacuum hoses on the carby. It fixed my problem and is cheaper than the booster idea but basically you have a vacuum leak somewhere and it is stalling the car as a result.
Post Posted: Fri Aug 03, 2012 9:26 pm
You may have split a hose during body lift.
There is a valve in the booster, or in the line, that controls the vacuum.
Was the problem with my Vit, but it had different symptoms.
Vehicle: SJ51T
Post Posted: Fri Aug 03, 2012 9:50 pm
Thanks chris, i will have to have a check of the hose tomorrow but I still have to get that extra filter before the carby like you suggested.
I think the fact my carby is piss-weak is part of any problem with my car.
Humble beginnings
Vehicle: 1985 lwb sierra UTE
Post Posted: Sat Aug 04, 2012 4:48 am
iv had the same problem ,same fix as zookfan
Green? greeeen is nice !
Users browsing this forum: Google Adsense [Bot] and 364 guests
