http://auszookers.com/forum/
braking = engine stall
http://auszookers.com/forum/viewtopic.php?f=5&t=34706
Author:  jonfromhamilton [ Fri Aug 03, 2012 6:00 pm ]
Post subject:  braking = engine stall
So I have noticed the revs fall when I press my foot on the brake and upon further investigation (pumping the brake) the engine dies down and stalls out comparitive to how much i pump the brake.
I assume this is a problem between the brake booster and the vaccum in the engine but this is where it gets beyond me.
ideas ?
Author:  want33s [ Fri Aug 03, 2012 7:07 pm ]
Post subject:  Re: braking = engine stall
Probably a split diaphragm in the booster.
Replace it or have it rebuilt.
Author:  abclarke [ Fri Aug 03, 2012 7:29 pm ]
Carby 1.3?
Author:  Zook_Fan [ Fri Aug 03, 2012 8:00 pm ]
When I installed my G16a I had the same problem in my sierra. Quite annoying in a rally when you jump on the brakes and the cars stalls :lol: . To fix it I replaced all of the vacuum hoses on the carby. It fixed my problem and is cheaper than the booster idea but basically you have a vacuum leak somewhere and it is stalling the car as a result.
Author:  christover1 [ Fri Aug 03, 2012 9:26 pm ]
You may have split a hose during body lift.
There is a valve in the booster, or in the line, that controls the vacuum.
Was the problem with my Vit, but it had different symptoms.
Author:  jonfromhamilton [ Fri Aug 03, 2012 9:50 pm ]
Thanks chris, i will have to have a check of the hose tomorrow but I still have to get that extra filter before the carby like you suggested.
I think the fact my carby is piss-weak is part of any problem with my car.
Author:  KEENSY85 [ Sat Aug 04, 2012 4:48 am ]
iv had the same problem ,same fix as zookfan
