It is currently Tue Nov 03, 2026 1:02 am
Post Posted: Sat Aug 04, 2012 7:33 am
Hi everyone
I have a 1986 Sierra NT that has a very worn gearbox. The selector mechanism is very sloppy and very expensive to repair.
Is it possible to find a low Km gearbox and put a rebuild kit in it (what are my chances of finding one), or could I put a Vitara manual gearbox in it?
Has anyone put a Vitara gearbox in a Sierra? If so, what is involved.
The engine has recently been rebuilt and I want to keep that in the car.
Many thanks
Chris
Post Posted: Sat Aug 04, 2012 7:54 am
With modification I can't see why you couldn't use a BenT or Petroworks bellhousing adapter to fit a Vitara 5 speed to a 1.3.
You'd have to weld up and redrill the countersunk holes from the other side.
Trans tunnel will need mods.
Vehicle: yellow 83 sierra
Post Posted: Sat Aug 04, 2012 10:28 am
my four speed was pretty sloppy to and only had 90,000 k's on it untill i broke the bolt that stops the gear leaver moving from side to side the bolt that it pivets off. so i replaced it and it made it alot better the bolt bolt was all flogged out and it just ended up snapping. i think from memory it was a 8mm bolt something like that i just put a couple of nuts in it to lock it up and she was fine
Post Posted: Sat Aug 04, 2012 10:32 am
also my gear lever where that bolt goes into it was pretty rounded out aswell
Post Posted: Tue Aug 07, 2012 7:23 am
Thanks for the replies. Does anyone know what would be considered a realistic low Km gearbox for these beasts? I can replace bearings, syncros and seals, but replacing them is a waste of time if the selector hub is worn out (like the one I currently have).
Also if I went down the Vitara gearbox path, would I need a specially made shaft to connect from the vitara gearbox to the Sierra Transfer case?
Post Posted: Wed Aug 08, 2012 2:01 pm
U need to get ur jack shaft cut down as the vit box is longer i think
Do u have a 1.3or 1L
Post Posted: Thu Aug 09, 2012 6:49 am
I have the 1.3 litre motor.
Post Posted: Thu Aug 09, 2012 8:20 am
I think early jimmy box might fit
Should be able to find one with less kms and not have to suff round with adaptors tunnel mods etc
Post Posted: Fri Aug 10, 2012 6:48 am
Do they have 5 speed boxes?
Post Posted: Fri Aug 10, 2012 12:18 pm
Yes.
Infact the G13BB gearbox internals are completely interchangable with sierra internals.
But got_bar_work may be giving you a bit of a bumsteer there. Finding a low km's BB jimny is still going to be quite hard, as they are now 12-14 years old too.
Post Posted: Fri Aug 10, 2012 5:07 pm
Thanks Fatzook for the info.
I will have a better chance of getting lower Km compared to my 1986 Sierra.
Users browsing this forum: Google [Bot] and 117 guests
