It is currently Wed Oct 14, 2026 9:59 am
Vehicle: 93 vitara estate
Post Posted: Mon Aug 06, 2012 2:33 pm
hi all
need a bit of info from the pros here
my oil sump gasket has shat itself and its leaking way too much to keep on driving the car.
my question is , is there enough room to replace the gasket just by undoing the sump or do i have to take out the engine?
cheers
Post Posted: Mon Aug 06, 2012 4:05 pm
i'm guessing the G16B is fitted to a Vitara... pretty sure you'll need to drop the front diff to get access to all the sump bolts, still easier than removing the engine.
Post Posted: Mon Aug 06, 2012 4:20 pm
Looking under mine I don't think there would be enough room unless you drop the diff but I could well be wrong as usual :wink:
Vehicle: vits
Post Posted: Mon Aug 06, 2012 4:21 pm
Are you sure it is the sump gasket and not the front main seal?
Post Posted: Mon Aug 06, 2012 4:34 pm
Tony, you should get some industrial strength bug spray for that bee in your bonnet. :wink:
Post Posted: Mon Aug 06, 2012 4:45 pm
Which one? - I was being serious - There does not LOOK to be enough room under mine but I don't KNOW.
Post Posted: Mon Aug 06, 2012 5:57 pm
haha, i've got a few too... but i think they're wasps or hornets. 8O
just noticed that you've started the "wrong as usual" thing since the plywood thread. :wink:
it's definately a diff out job, but as britvit said it's probably the front or rear main seals.
Post Posted: Tue Aug 07, 2012 5:09 am
Has it got a gasket? most of them just use sealant.
2000 Suzuki Vitara 1.6 8V
1986 Suzuki SJ413K
Post Posted: Tue Aug 07, 2012 8:01 am
The one I am about to rebuild has one - Sump Gasket that is.
Buzzzzzzz...................... That one flew away long ago Atari
Post Posted: Sat May 04, 2013 9:28 pm
Just wondering the same thing. I have a g16a fitted in a sierra with a 2" spring lift and am hoping it is possible to remove the sump and replace the gasket without all the other hassle of pulling the motor or dropping the diff. could someone clear this up for me.
many thanks
Post Posted: Sat May 04, 2013 10:42 pm
many thanks
If the G16 has a Sierra 1.3 sump fitted you will have enough room to remove it.
Users browsing this forum: Google [Bot] and 341 guests
