It is currently Mon Nov 02, 2026 2:14 am
Vehicle: 1990 Suzuki Sierra
Post Posted: Mon Aug 06, 2012 3:59 pm
Hey I have a 1990 Suzuki Sierra 1.3L carby. And it is currently using about 16L/100kms. I was having a look at some forums and most people are getting roughly 10-12L/100kms. I redone all the carby and cleaned it out. It has 215/80 R15 tyres on it. So if anyone could help me out as to why it's using so much fuel that would be great.
Cheers Grant
Post Posted: Mon Aug 06, 2012 4:06 pm
Only real thing I can think of is the mixure is way too high. Does it blow back smoke when you rev it? I don't know a lot about it but that is my first thoughts.
Does it have std jets in the carb?
Vehicle: 91 WT 1.6EFI
Post Posted: Mon Aug 06, 2012 5:06 pm
Sounds about right I was getting about 180-210 kilometers out of 33L
Post Posted: Mon Aug 06, 2012 5:25 pm
Sounds about wrong. Zooks will get around 10lt per 100 driving easy or hard.
16lt is way high. My sort of daily driver zook with 29" gets 300km EASY with a fill of about 30 to 32lt.
Vehicle: SJ80, SE416
Post Posted: Mon Aug 06, 2012 6:02 pm
Cheers Grant
Hmmmm... many possibilites:
Timing is set wrong
Ignition system needs replacing
Carby needs rebuild
You have a vacuum leak
Your engine has low compression
You have a valve problem
Your cat converter is clogged
You have stuffed brake caliper slides
You have stuffed wheelbearings
More info or checking needed for an internet diagnosis...
Post Posted: Mon Aug 06, 2012 6:04 pm
Mine gets around 16l per 100 too. :lol:
Adding to the above, replace your airfilter and check that your fuel pump isn't leaking.
Post Posted: Mon Aug 06, 2012 6:24 pm
Well yours is fucked as well sideways :-)
Post Posted: Mon Aug 06, 2012 7:03 pm
I wish I could say that's the only thing that's wrong with it! :lol: Seriously, the clutch is the only part of it that doesn't have serious issues. :oops:
Vehicle: 91 Sierra
Post Posted: Mon Aug 06, 2012 7:11 pm
Cheers Grant
Does it leave a blacK mark below the exhaust on start up ie spits out soot ? Does it puff black smoke at idle? It could be the choke is stuck open.
Post Posted: Mon Aug 06, 2012 7:17 pm
lauby wrote:
Cheers Grant
Does it leave a blacK mark below the exhaust on start up ie spits out soot ? Does it puff black smoke at idle? It could be the choke is stuck closed.
Fixed. :)
Vehicle: 91 Sierra
Post Posted: Mon Aug 06, 2012 7:19 pm
:lol:
Post Posted: Wed Aug 08, 2012 9:10 am
31's 6.5/3.7 gears G16b & Sierra 5 Speed, I get 300-320 from a tank. Doesnt make a difference on the driving (offroading excluded)
Users browsing this forum: Google [Bot] and 66 guests
