It is currently Tue Nov 03, 2026 1:02 am
Post Posted: Thu Aug 09, 2012 1:15 pm
Just finished off a G16A conversion on my sierra, using an auto choke carby off a swift, once warmed up it idles at about 2300rpm. The throttle stop screw is backed right off and the choke appears to work properly. Any ideas?
Vehicle: Yellow Ute
Post Posted: Thu Aug 09, 2012 2:41 pm
Does it rev lower than that with the choke on? When you were screwing the screw out were the revs dropping? The accelerator cable might be holding it on.
Post Posted: Thu Aug 09, 2012 3:00 pm
Cable is loose, no change in revs as screw was turned, pushing choke on by hand dropped revs.
Post Posted: Fri Aug 10, 2012 4:08 pm
Checked ignition timing, Was at 0 degrees so reset to 8, which only increased the revs :roll:
Users browsing this forum: Google [Bot] and 117 guests
