| Author |
Message |
JSilva
Vehicle: Suzuki Jimny 2000
 Posted: Tue Aug 14, 2012 12:06 pm |
Hello All,
I am new to this forum and also a new suzuki owner. I recently bough a jimny 2000 (G13B) and I would like to make some improvements to obtain a better performance offroad. I am in the process of doing the standard (eg. tyres, lifting kit and snkorkel) but I also like to know what I can do to improve the engine power. Also would appreciate some advise on recovery points. Thank you all for your help. Cheers
J
zukmeista
Joined: Sun Mar 22, 2009 10:30 pm Posts: 1273 Location: Whangarei,N.Z.
 Posted: Tue Aug 14, 2012 12:12 pm |
The best way to get more power would be to fit a G16B bottom end partnered to your G13BB head, that way there are no wiring issues and air intake stays the same.
tanshi
Joined: Tue Jan 09, 2007 10:30 pm Posts: 7717 Location: Brisbane
 Posted: Tue Aug 14, 2012 12:15 pm |
do you really need more power?
A baleno g16 would be a good swap into on of these. or a J20A if your more mechanically minded.
Depends on your skill set or budget
zooky08
Joined: Fri Nov 27, 2009 10:30 pm Posts: 3426 Location: imbil/gympie. qld
Vehicle: 03 Jimny
 Posted: Tue Aug 14, 2012 12:22 pm |
If you've put bigger tires on I would fix your gearing first. This is were your power lose would be from.
_________________ 03 Jimny 30 km2s 75mm lift f&r locked winch
JSilva
 Posted: Fri Aug 17, 2012 7:07 am |
Because I use this car as my daily car, would be good if I could drive at 100km/h without having the car on 4000h. I do not want to force the car on road. Thank you all for you feedback. Great site
zukmeista
 Posted: Fri Aug 17, 2012 7:57 am |
That is perfectly normal, that is the rev range they are designed to operate at. Lowering the revs will only reduce power and increase fuel useage.
JSilva
 Posted: Fri Aug 17, 2012 9:33 am |
Forgive my ignorance but I did not want to drive for an extend period of time in such high revs. Specially at the Freeway, where I have to seat at 100km/h. I really use the engine's power off road but I though that I was doing the right thing by taking easy on the road.
BlueSuzy
 Posted: Fri Aug 17, 2012 10:10 am |
What month make is your jim? M13a came out that year but unsure when they change over from g13bb to m13a
zukmeista
 Posted: Fri Aug 17, 2012 10:33 am |
JSilva wrote: Forgive my ignorance but I did not want to drive for an extend period of time in such high revs. Specially at the Freeway, where I have to seat at 100km/h. I really use the engine's power off road but I though that I was doing the right thing by taking easy on the road. That is the revs it needs to operate at, end of story.
BlueSuzy
 Posted: Fri Aug 17, 2012 11:17 am |
You can fit bigger tyres to make your revs lower. Good excuse to  But they will drain power also. Another option is to start playing with transfer gearing. There are not many options to change to lower diff gears because the front centre is fairly 'unique' to Jimny
Reubs
Joined: Wed Sep 09, 2009 11:30 pm Posts: 1522 Location: Brisbane
Vehicle: SJ80, SE416
 Posted: Fri Aug 17, 2012 11:39 am |
zukmeista wrote: JSilva wrote: Forgive my ignorance but I did not want to drive for an extend period of time in such high revs. Specially at the Freeway, where I have to seat at 100km/h. I really use the engine's power off road but I though that I was doing the right thing by taking easy on the road. That is the revs it needs to operate at, end of story. X2. Adding taller gearing reducing engine RPM will return less power, and you will use more fuel. Excessive RPM kills engines, however 4000RPM isn't excessive for a 1.3L engine designed to run continuously at that speed. Increase your tyre size and you will feel the added load caused by the change in gearing.
zooky08
Vehicle: 03 Jimny
 Posted: Fri Aug 17, 2012 12:02 pm |
Take my word on this, because I run big tyre with out gearing and I have not much power and my fuel millage is shot. I'm about 3700-3800 at 100 with 30" tyres. Highway driving is fine I can drive at that rpm for 3hrs straight and it's fine Round town I have power lose because I have no gearing. Jimmy engine torque range comes in around 3500rpm. So dropping your rpm under 4000rpm you will start to loose power. idk what engine you have but the m13a can rev happily on 4000rpm. I rev mine even higher then that. Like zukmeista said, start lowering your rpm then stock, you start having problems.
SkIpAi
Joined: Fri May 25, 2012 2:07 pm Posts: 114 Location: Mandurah, WA
Vehicle: 2000 JX Jimny
 Posted: Fri Aug 17, 2012 2:25 pm |
I run G13BB, 30" Muds with a Sierra WT transfer case and it sits on 3750rpm at 100km. Fuel economy is always around 9.5L/100km.
Im going 4:9's soon so I except it will be reving harder but I will take that for the off road performance.
squibby
Joined: Wed May 11, 2011 3:13 am Posts: 645 Location: Brisbane
Vehicle: On the lookout
 Posted: Fri Aug 17, 2012 5:32 pm |
Just because M13A can take a good thrashing all day long doesn't neccesarily mean thats ok for the G13B. G13B has a slightly long stroke according to wiki, so it doesn't lend itself to hi revs quite as easily as a short stroke M13 - at least on paper anyway.
Rhinoman
Joined: Mon May 16, 2011 7:03 pm Posts: 686 Location: Brinkworth, England
 Posted: Sun Aug 19, 2012 4:49 am |
squibby wrote: G13B has a slightly long stroke according to wiki, so it doesn't lend itself to hi revs quite as easily as a short stroke M13 - at least on paper anyway. On paper but the G13BB, as I recall, has the same bore and stroke as the G13B twin cam motor and that was a rev box. When I had a G13BB Jimny there was a noticable drop in performance and economy just going up to 215R15s
superduki
Joined: Thu Nov 05, 2009 10:30 pm Posts: 466 Location: Tasmania
 Posted: Sun Aug 19, 2012 3:33 pm |
Rhinoman wrote: squibby wrote: G13B has a slightly long stroke according to wiki, so it doesn't lend itself to hi revs quite as easily as a short stroke M13 - at least on paper anyway. On paper but the G13BB, as I recall, has the same bore and stroke as the G13B twin cam motor and that was a rev box. Correct. I hydraulic'd a G13BB and couldn't get a set of rods, so I started looking for alternatives and found the GTi G13B had the same rod. Fitted them with new shells and she loved it!
Dr_Snapid
Joined: Mon Jul 26, 2010 11:57 am Posts: 649 Location: Grafton
Vehicle: 2003 Jimny Auto
 Posted: Sun Aug 19, 2012 7:55 pm |
Dont be afraid of rpm in your jimny mate
motorbikes with these sized engines rev way higher, would you slow down to keep the revs down?
I know most people would consider 4000 rpm high but you have broadened your horizons by buying a suzuki. You will learn lots of neat stuff including how some of the things you thought you knew about cars dont always apply
Have fun
