It is currently Tue Oct 20, 2026 12:56 pm
Post Posted: Fri Aug 17, 2012 6:05 am
Is there a difference between where he cable fits into the transfer case from a 85 1.3 to a 96wt case?
I have had a leak since fitting a late 1.3 transfer to my lwb, out of the hole the cable goes into, have tried a heap of different O rings and a new nt cable for no improvement in the leak.
I am mostly certain that the case didn't leak when it was fitted to my 89 wt.
Any suggestions?
Post Posted: Fri Aug 17, 2012 7:05 am
They should be the same shep. 84 to 96 will be the same.
Post Posted: Fri Aug 17, 2012 7:22 am
There must be something wrong with it then as the cable is loose in the hole even with the lock bolt done up
Vehicle: LJ50V, SJ70
Post Posted: Fri Aug 17, 2012 8:31 am
In the hole? Huh? There is a collar on the end of the cable that screws on to a male thread on the speedo cable outlet. The only part of the speedo cable that goes into any hole is the cable itself into a square drive.
Besides the O-ring on the on the outside of the Speedo Driven Gear housing (thats the large bush-thing that is retained with the lock bolt), there is alo a small oil seal on the inside of the housing for the shaft of the driven gear. It might be that that's causing your oil leak?
Vehicle: SWB Sierra
Post Posted: Sat Aug 18, 2012 12:52 am
Never seen the above mentioned cable set up on a wt Sierra, my three t-cases and another I helped rebuild were the same as Sheps.
Post Posted: Thu Aug 23, 2012 1:09 am
Farrrrrk! Embarassing error. The set up I described with the collar retaining the cable on the Transfer end belongs to another model vehicle I have been working on. But the existance of the oil seal within the Speedo Driven Gear Housing is correct. Besides the obvious O-Ring on the out side, there is a seal on the inside. Tiny little bugger, but these are available from most bearing suppliers, or from Low Range Offroad (first item on the list)
Users browsing this forum: No registered users and 220 guests
