It is currently Mon Sep 21, 2026 1:22 am
Vehicle: 96 Sierra Tintop swb nt coily
Post Posted: Thu Aug 16, 2012 7:52 pm
hey guys ive installed a bl in my coily but the steering shaft is really tight to bolt up,can someone tell me the thickness of the spacer that generally comes with a bl kit,cheers.
Post Posted: Thu Aug 16, 2012 8:01 pm
20mm. Be carefull here. You fuck it up and you'll be in line for a mega accident.
Post Posted: Thu Aug 16, 2012 8:41 pm
y's that?
Post Posted: Thu Aug 16, 2012 9:40 pm
Another option may be to extend/retract the steering shaft. A coily should have a collapsible steering shaft to allow this.
I had to shorten mine for a power steering conversion and then lengthened it again slightly when I put my body lift in.
Post Posted: Fri Aug 17, 2012 5:35 am
Look up just cruizins ad in the business section. He sells the spacers in poly, with crush tubes, longer bolts etc, everything you need to make it easy. Cheap too!
Post Posted: Fri Aug 17, 2012 5:38 am
My bad, he doesn't list them separately, only with the body lift kits. But he does sell them separately so pm him for a price.
Post Posted: Fri Aug 17, 2012 9:32 am
I think he sells them for 20 or 30 bucks... very worthwhile!
Post Posted: Fri Aug 17, 2012 7:17 pm
yeh 30 bucks already msg'd him. i was gonna make one up at work,already got the dimensions and roughed it up,using nylon with crush tubes for the material,should do the job nicely.
Post Posted: Fri Aug 17, 2012 7:42 pm
This has got to flex remember and your steering relies on it. The material used in these biscuits is engineered to be suitable for the application. If you are not certain the material you are using is suitable please consider the risk you are imposing on yourself and others. Not saying you have to buy it off me just make sure what you use is fit for purpose.
Vehicle: 1985 Holden Drover
Post Posted: Fri Aug 17, 2012 7:54 pm
x100
Vehicle: Nl pajero Lwb, 98 jimny
Post Posted: Fri Aug 17, 2012 8:01 pm
For $30 why would anybody even bother trying to rig up some half dodgy thing? That's like a pack of smokes a meat pie and a coke, I am sure most who own a vehicle could afford that... Even if unemployed it's still not that pricey.I could very much understand making bits if nothing was available to purchase as sometimes is the case. Steering and brakes and airbags... Just don't mess with them bits I reckon.
Post Posted: Fri Aug 17, 2012 8:03 pm
cause most suzuki owners are tight arses & don't like to part with the $$$$'s
Post Posted: Fri Aug 17, 2012 8:07 pm
Lol I gave up racing karts earlier this year after tallying up last seasons race costs.....$57k. Zooks to me are fun AND cheap as chips! If you bust one up to badly.... Just replace it and do a part swap!
Post Posted: Fri Aug 17, 2012 8:19 pm
People have issues though if $30 is really something youd risk your life making yourself? :lol:
Post Posted: Fri Aug 17, 2012 8:24 pm
I am sure he said in his post he started to make one before he found a safe cheap proven part for sale.
Post Posted: Fri Aug 17, 2012 9:36 pm
too right bigdog.
i have machined i 30mm piece of nylon at my work with the bolts and new holes but it seemed too thick so i waa just wantibg to know what the notmal thickness and material was. ill more then likely end up getting one from justcruisin because as ut has been pointed out quite obviously my safety and others is a priority over $30.
Post Posted: Fri Aug 17, 2012 9:39 pm
i also have high density rubber i can use if it would be more suitable to accomodate the flex you mentioned.
Users browsing this forum: No registered users and 202 guests
