It is currently Wed Oct 28, 2026 7:28 am
Vehicle: 2002 Jimny
Post Posted: Sat Aug 18, 2012 6:50 pm
Hey guys,
Had a bit of a rollover today, slow speed low impact only a bit of a dent behind the door.
It rolled onto the right side and after getting it upright and starting it we found the fan rubbing agains the plastic guard that goes around it. It was rubbing on the top right side where the radiator hose, its as if the motor has moved towards the right. After cutting the guard off and driving home there is a clunking coming from the gear box in 1st and 2nd gear and 3rd under load. Everything appears to be straight and its driving straight, could the motor have shifted on its mounts? Any thoughts on what might be going on??
Thanks!
Post Posted: Sat Aug 18, 2012 7:15 pm
Sounds like the body could be shifted to 1 side
Check engine and gbox mounts. They could be broken
Post Posted: Sat Aug 18, 2012 10:53 pm
This seems to be a common occurance of late.
Post Posted: Sun Aug 19, 2012 8:24 am
When I tipped mine onto its riht side, my left mount broke and the engine rolled to the right and shifted back so the outer shell of the mount was sitting on the rubber block. This caused the gear box to be way out of place and the fan to hit the shroud. We had to jack the engine up, and lever the mount back over the block. Still rocked under load but was the least of the issues that weekend. All part of the fun and experience.
Vehicle: 2002 Jimny
Post Posted: Sun Aug 19, 2012 6:06 pm
Thanks mate, I didn't have time to have a proper look today but will tomorrow, might lead to more questions
Vehicle: On the lookout
Post Posted: Mon Aug 20, 2012 11:03 am
:lol: Was just going to ask 'where is Bugsta when you need him?' what he doesn't know about rolling jimnys ain't worth knowing :peaceout:
Users browsing this forum: Google [Bot] and 259 guests
