It is currently Fri Oct 30, 2026 3:45 pm
Vehicle: SJ51T
Post Posted: Sat Aug 18, 2012 9:21 pm
I posted this here because in the n00b section it states (no flame zone)
so... flame on!
bearing --> collar --> brakes = wrong order
Post Posted: Sat Aug 18, 2012 9:24 pm
:rofl:
flame turned on but with minimum real low setting
stephen
been there- done that too Armsup
Post Posted: Sat Aug 18, 2012 9:36 pm
whoops
Vehicle: SJ51T
Post Posted: Sat Aug 18, 2012 9:40 pm
I had plans for tomorrow after having got my Sierra all ready for an upcoming trip.
Now my plans are going back to repco to give more money away then hurridly finish this job :( poos
Vehicle: LWB Sierra & XL7
Post Posted: Sat Aug 18, 2012 10:52 pm
I'll put this one down as you focusing on the main job and forgetting 'minor' details.. I've done that before but it's one of those things that you won't forget not to do again. Lessons learned the hard way rule :D
'92 Vitara & Camper trailer
Post Posted: Sun Aug 19, 2012 5:33 am
dickhead............. I put the bearing on back the front :lol:
Post Posted: Sun Aug 19, 2012 5:48 am
You should be able to get it off with out having to buy a new bearing
Post Posted: Sun Aug 19, 2012 5:59 am
btw. these guys are good. Hartnett drive.
http://www.frankstonbearings.com.au/
Post Posted: Sun Aug 19, 2012 8:02 am
Disc rear conversion would negate that issue.
So would 1.0 Litre backing plate type design.
I'm told you can convert, but no idea how its done.
Post Posted: Sun Aug 19, 2012 8:10 am
If it's freshly pressed on, you can press it off.
Been there done that :lol:
Post Posted: Sun Aug 19, 2012 9:02 am
I would have thought so too.
Vehicle: SJ51T
Post Posted: Sun Aug 19, 2012 6:51 pm
yeah I know them. but I was at work in Springvale trying to get this all done without a press.
I finished the job now (making a new problem with the brakes)
I used a ball pein hammer as a punch and a little bit of a bigger hammer to strike it either side of the collar or bearing to get the job done.
took a very long time :S like over an hour.
also striking the collar sort of mushroom headed it but angle grinder fixed that, pretty sure that the oil seal won't run on that bit :D
this was a bigger job than i had anticipated akin to putting gears in the t-case so probably should have made sure I was in the right workshop for it.
Vehicle: SJ51T
Post Posted: Sun Aug 19, 2012 6:53 pm
The bearing butted up to a shoulder on the axle flange that made me think twice about trying to pressi t off with no press :(
also cbf
Users browsing this forum: No registered users and 385 guests
