It is currently Mon Sep 21, 2026 2:53 pm
Vehicle: 95 sj70 and 78 lj81
Post Posted: Sun Aug 19, 2012 1:16 pm
Looking to get a new filter for my 1.6 just wondering if anyone has found a cheaper (read that not worse quality) filter to use. Like a high use item out of a commy or something
Vehicle: tin top sj70
Post Posted: Sun Aug 19, 2012 1:20 pm
hey burls did you buy you sierra off a guy in townsville called matt ?
Post Posted: Sun Aug 19, 2012 1:40 pm
If you are talking about a G16B EFI filter, yes, you can use a VL commodore filter, they are pretty cheap. However, this is a "point of no return" mod as you'll need to cut the banjo fitting off the HP hose coming from the tank.
I had a VL commodore filter on my car when it was 660cc powered (vitara tank) I've since swapped to a proper G16B filter to retain the banjo fittings.
I bought a replacement G16B filter from Repco and didn't remember it being very expensive?
Post Posted: Sun Aug 19, 2012 2:11 pm
Repco do a universal replacement.
RFF75 has a crown around it to run the pipe in in any direction.
Around $27
Post Posted: Sun Aug 19, 2012 2:27 pm
I think that's about what I paid.
You might be able to find a VL filter for $10 or so, but in any case, and EFI filter shouldn't require replacement very often - there's a strainer on the bottom of the pickup that catches most of the junk, so there shouldn't be much debris making it's way into the filter.
Post Posted: Sun Aug 19, 2012 3:22 pm
Thanks guys
Steve I am at the start point, thats why I didnt designate a car. I can fit any filter I like (within reason) as I have to make the brackets and all the lines. This is in my LJ81. So the idea was to find a common use filter that is cheaper due to volume sales not quality.
Users browsing this forum: Google [Bot] and 120 guests
