It is currently Mon Oct 26, 2026 12:52 pm
Post Posted: Sun Aug 19, 2012 3:10 pm
Probably a noob question ,but the rubber grommets in the floor well of my sierra have gone AWOL. Are they easily sourced ?
Post Posted: Sun Aug 19, 2012 3:22 pm
Yes..
Vehicle: SWB Sierra
Post Posted: Sun Aug 19, 2012 3:39 pm
Very helpful
Lror have them. Generic ones that may also fit can be purchased from Purple Pig or Clark Rubber. I imagine suziauto, suziworld etc can also supply them.
Some of the generic ones are too thin for foot wells and will fallout with any pressure. Filling the indentation with silicone increases the rigidity.
Post Posted: Sun Aug 19, 2012 3:43 pm
eBay it, their is a company on their that sells the complete car rubber grommets.
I bought a set when rebuilding my car and they aren't quite as good as the factory (bit thinner in thickness) but fit well.
Post Posted: Sun Aug 19, 2012 4:14 pm
4wdproducts sells them on ebay.
Post Posted: Sun Aug 19, 2012 5:15 pm
Wreckers are a good place.
Vehicle: Clown Car..
Post Posted: Sun Aug 19, 2012 6:16 pm
off memory they are about 90cents at clark rubber, fit is tight, and solid. Just how it ough to be..
Vehicle: '94 suzuki maruti
Post Posted: Sun Aug 19, 2012 7:43 pm
i probably bought the wrong ones, but when i went to clark rubber, they had some that were way too big, or slightly too small (fit, but werent water tight at all and even a light bit of weight would push them through)... recently bought proper plugs from suzistore (see link at end). whilst not as cheap as clark rubber, they are worth it IMO, and were under $30 for a set of four express posted. only problem ive had with them is after it rains i need to pull them out to let out water thats leaked in from the windscreen seal.
http://www.suzistore.com.au/shopexd.asp?id=20
Post Posted: Mon Aug 20, 2012 7:34 am
you can also use the sink drains out of your bathroom the ones that pop up and down
http://ts3.mm.bing.net/images/thumbnail ... 37efcc5689
josh AKA Bazook
Vehicle: On the lookout
Post Posted: Mon Aug 20, 2012 12:34 pm
Apparently you can fail your roadworthy without these. That's what I was told. I just need some so my amps and sub don't get swamped fording a river. :)
Vehicle: LJ80
Post Posted: Mon Aug 20, 2012 1:07 pm
^^ i did :evil: took me two minutes to silicone a piece of plastic in to pass (45min wasted driving home and back though)
then i found the right one in my driveway :roll:
Users browsing this forum: Google [Bot] and 360 guests
