http://auszookers.com/forum/
getting dorrs off
http://auszookers.com/forum/viewtopic.php?f=5&t=3515
Author:  _noddy [ Tue Dec 09, 2008 3:23 am ]
Post subject:  getting dorrs off
Im trying to get my doors off but the bolts are shit i have tryed one of theos bashey things wat eles can i try.
Author:  Mike [ Tue Dec 09, 2008 3:28 am ]
Post subject:  Re: getting dorrs off
weld a nut onto the screw and use a ratchet/breaker bar
Author:  just_cruizin [ Tue Dec 09, 2008 4:07 am ]
cold chisel
Author:  Mike [ Tue Dec 09, 2008 4:25 am ]
just_cruizin wrote:
cold chisel
just play khe sahn really loud and the doors will fall off :wink:
Author:  BlueSuzy [ Tue Dec 09, 2008 4:28 am ]
8O Now what the?
Author:  hooki [ Tue Dec 09, 2008 8:25 am ]
haha jimmy barnes
Author:  royce [ Tue Dec 09, 2008 11:52 am ]
Blow torch
Author:  Damo [ Tue Dec 09, 2008 1:53 pm ]
You can try mechanical methods like the impact driver or a cold chisel. I have used the big screwdriver bit from the impact driver and put it onto my rattle gun :lol: which worked a few times but after a while it just shatters the bit like glass!!
If none of that works you need to introduce some heat. Like Royce mentioned a blow torch should do it. An oxy will work too. If you weld a nut onto the head of the bolt the heat from the weld will make it easy to undo, and as a bonus you willnow have a nut to put a spanner on too.
Author:  just_cruizin [ Wed Dec 10, 2008 6:14 am ]
park on a main street and throw the door open when a taxi goes past.
Author:  appsie [ Thu Dec 11, 2008 2:26 am ]
i like some of these methods fellas.I have always done mine with a cold chisel and tapped it loose tho.can be a pain at times but once your running bolts instead of those ridiculous screws its great
Author:  Hybrid [ Thu Dec 11, 2008 6:19 pm ]
You could cut the top tube of your hinge off and make the doors removable. Thats what I did so I could swap between full doors and half doors (yet to be cut down). You just open the doors and lift them off.
