| How to get chromos together? http://auszookers.com/forum/viewtopic.php?f=5&t=35172 |
| Author: | suzukikid [ Wed Aug 22, 2012 5:42 pm ] |
| Post subject: | How to get chromos together? |
Hey all im trying to get my chromos together.... first up how do you get the circlip over into its groove thing? And then does the cv just slide on or is there a trick to it(I went on youtube and could only find 1 video of putting it together but the clip was already on there and he put a hose clamp around the clip so it gos into the cv easyer and the hose clamp slides down?) Is there a video on youtube for putting them together that i missed? cheers |
| Author: | Bruce [ Wed Aug 22, 2012 6:00 pm ] |
| Post subject: | Re: How to get chromos together? |
You need to pull the complete hub off and then fit the CV in the housing and slide the hub onto the CV. It will not fit in the normal way. You need to pull the swivel hub seals off. |
| Author: | Blkfxx [ Wed Aug 22, 2012 6:04 pm ] |
I think he is wanting to put the cv on the axle shaft. |
| Author: | Bruce [ Wed Aug 22, 2012 6:15 pm ] |
Photo of what you are trying to do then. |
| Author: | suzukikid [ Wed Aug 22, 2012 6:54 pm ] |
Yeah I know you need to pull the front end apart I'm just trying to get the chromos them self together!!!! Ya get the 2 cvs, long and short side axels and the 2 Cmcirclips to hold the cv on the axel.... I want to know how ya put them together! Haha |
| Author: | Bruce [ Wed Aug 22, 2012 7:27 pm ] |
You put the clip on, put the CV over the axle and hit it on. Takes a bit but it will go. Short sharp hit on the CV with a hammer and lump of wood. |
| Author: | monley [ Wed Aug 22, 2012 9:45 pm ] |
Bruce wrote: You put the clip on, put the CV over the axle and hit it on. Takes a bit but it will go. Short sharp hit on the CV with a hammer and lump of wood. Really? I just pushed mine on by hand and they clicked in place. I can't seem to pull them off with ease either, so im guessing they are on correctly? |
| Author: | Aaron [ Thu Aug 23, 2012 4:47 am ] |
Make sure to grease the cv while the 2 are apart. It's much easier than with the axle in there. |
| Author: | BlueSuzy [ Thu Aug 23, 2012 8:03 am ] |
x everything people have said. Holding the axle vertical on a piece of wood, place cv on top of axle, lift up assembly then drop onto wood, make sure the axle hits the wood...Gravity will do its work. Depends on how tight the splines are and how strong the clip is, alittle more force may be needed. Once its clipped on, thats it. Toyota cvs are similar, i found a youboob vid of how to get it apart a while ago. Wood on vice, make cv hit wood but not axle by holding it up and dropping onto it, clip will pop in or break, and cv is free from axle. |
| Author: | SierraDan [ Thu Aug 23, 2012 8:08 am ] |
I drop them into 50mm RHS. |
| Author: | Bruce [ Thu Aug 23, 2012 8:33 am ] |
monley wrote: Bruce wrote: You put the clip on, put the CV over the axle and hit it on. Takes a bit but it will go. Short sharp hit on the CV with a hammer and lump of wood. Really? I just pushed mine on by hand and they clicked in place. I can't seem to pull them off with ease either, so im guessing they are on correctly? Yep was only a light tap and it went on. Yes, once they are on it's rather hard to get them off. |
| Author: | suzukikid [ Thu Aug 23, 2012 10:28 am ] |
Righto! I'll just put that clip on the axel and go for it....thought there might be an easy way to get the clip on? |
| Author: | tanshi [ Thu Aug 23, 2012 10:53 am ] |
they should just stretch on pretty easy |
| Author: | suzukikid [ Fri Aug 24, 2012 6:06 pm ] |
all i needed was another set of hands to get the clip on then was easy as! cheers guys |
