It is currently Mon Aug 03, 2026 8:41 pm
Post Posted: Wed Aug 22, 2012 9:56 pm
Its a long shot but does anyone know the dimensions or the numbers off the needle bearing that runs on the main shaft. ( the bigger needle bearing on the biggest shaft)
Thanks in advance
Vehicle: LJ50V, SJ70
Post Posted: Thu Aug 23, 2012 1:23 am
Long shot alright. What vehicle for starters?
Post Posted: Thu Aug 23, 2012 6:34 am
Sierra wt
Post Posted: Thu Aug 23, 2012 7:36 am
I got my old bearings on my bench. I'll have a look shortly
MY BUILD THREAD HERE!!!!!
Post Posted: Thu Aug 23, 2012 7:55 am
Okay,
well out of all the needle bearings i took out, the biggest ones i had on the bench were a set of 2. both identical. and SGP p/n is 29985-80050 I didnt get any measurements cos my vernier ran out of batterys.
They were the only bearings in the rebuild kit that were NOT koyo, so im guessing they were suzuki only bits but cant be 100% on that. I can get measurements later if that info is not sufficient.
Keep in mind i cant confirm these are actually the ones you are chasing, i just went for whichever were the biggest.
Post Posted: Thu Aug 23, 2012 9:53 am
The needle roller bearings on the countershaft ( prop shaft/ idle shaft ) are identicle and are approx. 31mm long, 33OD, 27ID.
The needle roller bearings on the main output shaft are larger, with the one on the front output end being approx 40mm long and ID of 44mm. And the other being approx 35mm long with ID of 44mm also.
All these dimensions were measured through plastic, but should be good enough to identify a bearing from a list of SGP#'s.
Post Posted: Thu Aug 23, 2012 11:03 am
Sweet thanks guys. Its just suziworld said he couldn get one so im just chasing it up through random bearing shops but im not home to measure it cheers.
Post Posted: Thu Aug 23, 2012 11:52 am
They are VERY hard to find, as its not a common size.
PM Weaves http://www.auszookers.com/forum/memberlist.php?mode=viewprofile&u=377 .
If he can't get them, then they are genuine only.
Post Posted: Fri Aug 24, 2012 9:14 am
Well i rung around and it turns out its a genuine only bearing and i have to wait for it from japan dam!
So just for future reference the bearing is 35mm id 41mm od and 40mm long. I do not know the numbers though.
Post Posted: Fri Aug 24, 2012 10:01 am
guess you missed my post?
Post Posted: Fri Aug 24, 2012 4:53 pm
10 days from lowrange.
Post Posted: Sat Aug 25, 2012 4:53 pm
try 4wd_products on ebay. they sold me the kit, sure they could sell you the ones your chasing.
Post Posted: Sat Sep 01, 2012 5:34 pm
those bearings that are identical run on the intermediate shaft and are not the ones i was after but thanks anyway. suziworld is getting me one now thanks guys
Users browsing this forum: No registered users and 82 guests
