It is currently Tue Oct 20, 2026 2:16 am
Post Posted: Thu Aug 23, 2012 12:24 pm
Hey everyone,
A few days ago I picked up a new Sierra/Drover. It's a 1985 deluxe model with all the standard parts. When I went to look at it originally it had a problem were the car would rev a bit high and tend to stall from time to time (Coming from higher rpm to stationary). The next day when I got home I did a bit of a service ( oil, oil filter, air filter, spark plugs, coolant, leads, dizzy and the rotor button from the dizzy). Whilst I was doing the service I noticed a large amount of vacuum lines were missing, So I got online and found a Drover service manual and tried to match the lines up as best as I could.
However once I did all those vac lines the car started running rough and missing (There was a slight miss before the service, but now its worse). It struggles to start and stay running, once I do get it running and take it for a drive I have a lack of power until about 3500rpm then the car pulls again, it seems very hesitant at times, especially when it begins to move from a stationary position.
Yesterday I removed all the lines I had added and the car still ran rough, I even took it to Suzuki shop in Cannington and the they told me the timing was a little bit out but there is something else going on (seems like the car is running on 3 cylinders and runs worse when the choke is held open). When I got home that day I started to remove each lead while the car was running to see if there was a change in idle. I noticed when I removed the ignition lead corresponding to cylinder 4 there was no change in idle, I removed the lead and held it to the body and there was a spark. Following that I removed the spark plug and noticed it was wet. I installed the plug into the end of the lead and sure enough the spark plug had a strong spark. That led me to believe that for some reason cylinder 4 is not firing.
Would any one have an idea as to what is going on? I've attached some photos of the vacuum lines, If some one is able to confirm that the lines go to the correct location that would be appreciated.
http://imageshack.us/photo/my-images/707/imag1348z.jpg/
Idle solenoid (one on the right was what was in the car, left one is out of another zook which I installed)
http://imageshack.us/photo/my-images/33/imag1349a.jpg/
http://imageshack.us/photo/my-images/827/imag1350q.jpg/
http://imageshack.us/photo/my-images/10/imag1351c.jpg/
http://imageshack.us/photo/my-images/829/imag1353d.jpg/
http://imageshack.us/photo/my-images/836/imag1354.jpg/
Thanks for your time, Ni
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 240 guests
