It is currently Fri Sep 25, 2026 5:49 pm
Post Posted: Mon Aug 27, 2012 5:25 pm
Has anyone replaced or had anything to do with the kickdown/gearbox throttle cable?
Post Posted: Mon Aug 27, 2012 5:32 pm
Is there a question behind your question?
I've removed and refitted one, but not sure where you are going with this so thats as much help as I can be for the moment...
Post Posted: Mon Aug 27, 2012 5:44 pm
Sorry long day at work :oops: . How easy it is to replace and what i have to do to remove it? Mine is seized i cant move it by hand or with it connected to the throttle body.
Post Posted: Mon Aug 27, 2012 9:16 pm
Same sort of thing as an accelerator cable. Just undo both ends, fit the new one ( if you can find one.....) and carry on :wink:
Post Posted: Mon Aug 27, 2012 10:13 pm
Thanks fatzook. Is it attached to the valve body as well?
Post Posted: Mon Aug 27, 2012 10:20 pm
Post Posted: Mon Aug 27, 2012 10:22 pm
Just disconnect both ends, and any cable clamps etc and it will come free. In the above pic, you can see it looped up on top of the box.
Post Posted: Tue Aug 28, 2012 7:01 pm
Thanks again Fatzook
Users browsing this forum: Google [Bot] and 337 guests
