It is currently Tue Oct 20, 2026 9:45 am
Vehicle: 1992 vitara
Post Posted: Sat Aug 25, 2012 1:00 pm
hey guys i have just been looking at these on ebay http://www.ebay.com.au/itm/1x-4X4-RETRE ... 3f1a5d013c
i was just wanting some opinion on them?? how long do you think they would last offroad??
is it worth it??? cheers
Post Posted: Sat Aug 25, 2012 1:07 pm
Have a look through these two threads. Personally I think retread tyres are for drive tyres on trucks or heavy trailers only
viewtopic.php?f=5&t=26570&hilit=Retread
viewtopic.php?f=5&t=34542&hilit=Retread
Post Posted: Sat Aug 25, 2012 1:14 pm
for an offroad play tyre they will be fine, for $75 a pop you cant go too wrong. personally i'd have them on a 2nd set of rims so you're not tempted to daily drive them. try & find out of they are a recap or a bead to bead remold.
scrawn, just wondering what's the difference between fitting them to a truck/bus etc compared to a passenger vehicle/4wd?
Post Posted: Sat Aug 25, 2012 1:19 pm
cheers ill give them a go
is there much diffrence fitting them to 15x7 and 15x8
Post Posted: Sat Aug 25, 2012 1:20 pm
i'd put a 31x10.5r15 on a 15x7 before a 15x8.
Post Posted: Sat Aug 25, 2012 1:26 pm
ok cheers do you know what the offset would be? its for a 92 vitara
Post Posted: Sat Aug 25, 2012 1:32 pm
For starters, retreads for trucks are only allowed on drive axles, steer tyres have to be clean skin. Secondly, the tyres are always in pairs so if one tyre blows out (which is fairly common) then the other tyre will keep the rims off the road till the blown one can be replaced.
I realise the weights of truck vs Suzuki don't compare but I'd never be comfortable with retreads on my car, just a personal opinion. I'd hate to have a steer/front tyre blow out on the highway. If you used them as a second set for off roading then they'd probably go ok. I'd imagine they wouldn't balance very well either.
Post Posted: Sat Aug 25, 2012 1:39 pm
ahh cool, never new about not being allowed on the steer axle. being on a pair of duals makes sense.
Post Posted: Sat Aug 25, 2012 1:54 pm
im a manager of a courier and all the duel axel use retread but the stear are clean skin
Vehicle: 1985 lwb sierra UTE
Post Posted: Sat Aug 25, 2012 2:16 pm
Some bloke at work recons retreads arnt as dodgy as they used to be, but I dunno has any one ever run any on here
Post Posted: Sat Aug 25, 2012 2:21 pm
im going to give it a go.. the trucks at work use them and with 4 tone sitting on them every day and they seem to do the job for 4 to 6 mnth highway use so im think it will be good for me as i hardly drive mine to often on the road!!
Post Posted: Sat Aug 25, 2012 3:46 pm
yess!! click the links scrawn posted
Post Posted: Sun Aug 26, 2012 8:07 am
Thanks for the links I might look at getting some of them as well eventually
Post Posted: Sun Aug 26, 2012 8:11 am
mud retreads arent to bad im running a set now
Post Posted: Sun Aug 26, 2012 8:57 am
I've got a set can't complain but the fuel bill has come up a fair way
Post Posted: Sun Aug 26, 2012 9:11 am
^^^ if they're lager than what was on there, that can be expected.
but there is a fair bit of extra weight on a retread, the 235/75r15 Insa Turbo's on 15x7 rims weighed 34kgs each.
Post Posted: Sun Aug 26, 2012 9:16 am
What's that in inches
Post Posted: Sun Aug 26, 2012 9:19 am
the carcass is based on a 235/75r15 (28.9") but with the tread on them they're essentially the same size as my 31" MTR's.
there are pics in the other thread. :wink:
Users browsing this forum: Google Adsense [Bot] and 236 guests
