It is currently Tue Oct 20, 2026 4:15 pm
Vehicle: 82 1ltr, 93 1.3 with 6.5's
Post Posted: Sun Aug 26, 2012 5:36 pm
Trying to fit my g13a into my 82 nt zook
Just wondering if the engine mounts in a nt and wt with a 1.3 engine are the same size and design
Are the engine mounts on the chassis the same size and design or are they different
Just need somethin to help me fit in the 1.3 g13a into an 82 nt that had a 1ltr f10a engine in it
Post Posted: Sun Aug 26, 2012 5:51 pm
WT and NT are the same, engine mount wise.
Steve
Post Posted: Sun Aug 26, 2012 6:01 pm
Okay then
Is there a size difference between 1.3 and 1ltr mounts
Post Posted: Sun Aug 26, 2012 6:13 pm
Not as far as I am aware - the rubber mount is physically the same.
Post Posted: Sun Aug 26, 2012 6:17 pm
Is there any difference in the frame pieces that connect it from the chassis to the block
Post Posted: Sun Aug 26, 2012 6:21 pm
the mounts on the chassis are in different though.
Shape as well as position.
is that way U asking?
Post Posted: Sun Aug 26, 2012 6:29 pm
Yeah cause ive got the engine sitting in the bay but its about 30-40mm off the mount but not sure if theyre out of a wt or nt and if theyre for a 1.3 or a 1 ltr
And trying to avoid fabbin up new mounts
Post Posted: Sun Aug 26, 2012 6:48 pm
See build threads on G16 engine conversion for Sierra utes or maruti.
Pics of one liter chassis with 1.3 mounts welded on.
Have seen some very doggy adapter plates to use existing chassis mounts
but your mod plate engineer will not pass it
Post Posted: Sun Aug 26, 2012 6:54 pm
This is going to take a very long time if you ask one question at a time.
The rubber mount is the same WT/NT/1.0
The engine side brackets are completely different between 1.0 and 1.3
The chassis brackets are completely different between 1.0 and 1.3.
It is possible to make adapter plates to make the 1.0 chassis brackets work with a 1.3 engine, but they are quite large brackets. I helped Christover with this many years ago.
Post Posted: Sun Aug 26, 2012 7:08 pm
Thanks for that ill look into it see if i can find some build threads with conversions done or try nd get some chassis brackets
Post Posted: Sun Aug 26, 2012 8:22 pm
Zuzukie, is it a 82 tub and chassis?
Wat gearbox are U using?
5 speed 1.3? will it fit in tunnel and mounts ok?
Post Posted: Mon Aug 27, 2012 9:19 am
Its an 82 swb tub is seperate from the chassis (just bolts down)
Had a f10a 4 speed in it but putting in g13a 5 speed
Gearbox fits in the tunnel but mount need mods done
Users browsing this forum: No registered users and 437 guests
