It is currently Sun Aug 02, 2026 9:04 am
Post Posted: Thu Aug 30, 2012 6:34 pm
hi all,
im having issues getting the brakes to work on my coily, after my front right caliper failed half way up a decent rock hill i replaced both calipers to find my brakes didnt exist anymore.
now i have changed my booster and master cyl with a jimny one as i was advised they are the same, i have also replaced the rear cyls and shoes and pads up front.
my brakes become barely existant if i pump them up, but when i push the brake pedal in the revs increase bout 500 rpm and then a further 2-300 rpm for about a second or 2 when i release the pedal.
Help please i am stumped.
Post Posted: Thu Aug 30, 2012 6:40 pm
Have you bled the system properly?
Post Posted: Thu Aug 30, 2012 8:30 pm
Bled it the same as i always have and never had any problems.
iInfact i did a full refresh of the fluid.
Post Posted: Thu Aug 30, 2012 8:48 pm
Did you use a vacuum bleeder?
Post Posted: Thu Aug 30, 2012 8:58 pm
X2 And have you checked all the brake lines? alot of people have split brake lines and don't realize.
Vehicle: sierra
Post Posted: Thu Aug 30, 2012 9:14 pm
didnt suck air into the lines whilst bleeding? try a vac bleed
Post Posted: Thu Aug 30, 2012 10:52 pm
Ok never heard of vac bleeder, will look that up.
and i haven't found any leaking fluid but will check for splits anyway.
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 41 guests
