Super pro poly bushes are good stuff. I have a full set in my landy. They are very soft, more-so than rubber ones, but will outlast the rubber bushes easily. Not all poly bushes are rock hard articulation reducing chunks of plastic that crumble after 6 months.
Posted: Thu Aug 30, 2012 6:09 pm
I can supply castor bushes for Jimny. I have a set here that I can post to you. They use an offset drilled crush tube, rather than an offset hole through the bush, so will last longer.
Users browsing this forum: No registered users and 552 guests
