Super pro poly bushes are good stuff. I have a full set in my landy. They are very soft, more-so than rubber ones, but will outlast the rubber bushes easily. Not all poly bushes are rock hard articulation reducing chunks of plastic that crumble after 6 months.
Joined: Sat Oct 27, 2007 11:30 pm Posts: 14977 Location: The Hills
Posted: Thu Aug 30, 2012 6:09 pm
I can supply castor bushes for Jimny. I have a set here that I can post to you. They use an offset drilled crush tube, rather than an offset hole through the bush, so will last longer.
Users browsing this forum: Google Adsense [Bot] and 381 guests
