Page 1 of 1
[ 7 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
DAZOOK_96
Joined: Sun Jun 26, 2011 1:09 am Posts: 79 Location: Wyee, Nsw
 Posted: Thu Aug 30, 2012 6:34 pm |
hi all, im having issues getting the brakes to work on my coily, after my front right caliper failed half way up a decent rock hill i replaced both calipers to find my brakes didnt exist anymore. now i have changed my booster and master cyl with a jimny one as i was advised they are the same, i have also replaced the rear cyls and shoes and pads up front. my brakes become barely existant if i pump them up, but when i push the brake pedal in the revs increase bout 500 rpm and then a further 2-300 rpm for about a second or 2 when i release the pedal.
Help please i am stumped.
Fatzook
Joined: Sat Oct 27, 2007 11:30 pm Posts: 14977 Location: The Hills
 Posted: Thu Aug 30, 2012 6:40 pm |
Have you bled the system properly?
_________________ 2013 GV 1998 SV420 ute
DAZOOK_96
 Posted: Thu Aug 30, 2012 8:30 pm |
Bled it the same as i always have and never had any problems. iInfact i did a full refresh of the fluid.
Fatzook
 Posted: Thu Aug 30, 2012 8:48 pm |
DAZOOK_96 wrote: Bled it the same as i always have and never had any problems. iInfact i did a full refresh of the fluid. Did you use a vacuum bleeder?
Lockie666
Joined: Sat Apr 17, 2010 11:30 pm Posts: 1874 Location: Perth
 Posted: Thu Aug 30, 2012 8:58 pm |
Fatzook wrote: Have you bled the system properly? X2 And have you checked all the brake lines? alot of people have split brake lines and don't realize.
rustyzook
Joined: Tue Jul 29, 2008 11:30 pm Posts: 1092 Location: Tamworth- central coast
Vehicle: sierra
 Posted: Thu Aug 30, 2012 9:14 pm |
didnt suck air into the lines whilst bleeding? try a vac bleed
DAZOOK_96
 Posted: Thu Aug 30, 2012 10:52 pm |
Ok never heard of vac bleeder, will look that up. and i haven't found any leaking fluid but will check for splits anyway.
Page 1 of 1
[ 7 posts ] |
Users browsing this forum: No registered users and 71 guests
