http://auszookers.com/forum/
No brakes!!
http://auszookers.com/forum/viewtopic.php?f=5&t=35375
Author:  DAZOOK_96 [ Thu Aug 30, 2012 6:34 pm ]
Post subject:  No brakes!!
hi all,
im having issues getting the brakes to work on my coily, after my front right caliper failed half way up a decent rock hill i replaced both calipers to find my brakes didnt exist anymore.
now i have changed my booster and master cyl with a jimny one as i was advised they are the same, i have also replaced the rear cyls and shoes and pads up front.
my brakes become barely existant if i pump them up, but when i push the brake pedal in the revs increase bout 500 rpm and then a further 2-300 rpm for about a second or 2 when i release the pedal.
Help please i am stumped.
Author:  Fatzook [ Thu Aug 30, 2012 6:40 pm ]
Post subject:  Re: No brakes!!
Have you bled the system properly?
Author:  DAZOOK_96 [ Thu Aug 30, 2012 8:30 pm ]
Bled it the same as i always have and never had any problems.
iInfact i did a full refresh of the fluid.
Author:  Fatzook [ Thu Aug 30, 2012 8:48 pm ]
Did you use a vacuum bleeder?
Author:  Lockie666 [ Thu Aug 30, 2012 8:58 pm ]
X2 And have you checked all the brake lines? alot of people have split brake lines and don't realize.
Author:  rustyzook [ Thu Aug 30, 2012 9:14 pm ]
didnt suck air into the lines whilst bleeding? try a vac bleed
Author:  DAZOOK_96 [ Thu Aug 30, 2012 10:52 pm ]
Ok never heard of vac bleeder, will look that up.
and i haven't found any leaking fluid but will check for splits anyway.
