It is currently Sat Oct 17, 2026 6:30 am
Post Posted: Mon Dec 15, 2008 1:09 am
i have a 2' spring lift, 2' extended shackles, and 2' bodylift and 31s atm just wondering if 33's will fit on with this lift?
Post Posted: Mon Dec 15, 2008 1:18 am
no, 31s will still scrub with that setup
Post Posted: Mon Dec 15, 2008 1:25 am
whats needed to go 33's? SPOA? bigger body lift?
Post Posted: Mon Dec 15, 2008 1:40 am
Depends what offset.
Depends where your front diff and (not so much) rear is.
Depends what size 33" wide or realsize 33".
Depends if your Suzy flexes.
Depends if your friends with a BFH
Spua.
See my buildup :wink:
Mine is lower then yours on 31's. Minimal scrubbage(only behind headlight a tad) And flexes more then most suzys on ere. Leafy's anyway..
Post Posted: Mon Dec 15, 2008 1:52 am
oh k cool. im not looking at doing it for a while as i only just got 31s but looking at options for next time. i like the look of the 33x12.5 baja claws which are only 44mm bigger then my 31' baja mtz. id have to get different offset wheels probably be worth while now anyway. what offset are you running?
Post Posted: Mon Dec 15, 2008 2:06 am
Biggest off shelf. +28 15x8 king wheels.
Also people will say run a thinner tyre. Helps with scrubbing, as well as a thinner rim. As well as less offset.
But i went the option without too many dramas. Plan, Buy, Then make them fit.
Post Posted: Mon Dec 15, 2008 2:12 am
mine isn't that flash but the only place it scrubs is the back of the passenger side tyre just touches the spring at full lock. 30mm bumpstop spacer, diff moved 40mm forward, 50mm body lift, old saggy 75mm springs with a few leaves removed and 25mm shackles. and i still had to use a BFH. 32x10.5x15 on f100 rims
Post Posted: Mon Dec 15, 2008 5:01 am
diameter won't be your problem, width will be though
Users browsing this forum: Google [Bot] and 229 guests
