It is currently Thu Nov 05, 2026 4:19 pm
Post new topic Reply to topic  [ 44 posts ]  Go to page 1, 2  Next
Post Posted: Wed Sep 05, 2012 10:47 pm
Would it be possible to run a "G" series Vit/Sierra box behind a "M" series motor? I haven't got a either to look at, nor have i ever played with gear boxes, but apart from the piss weak "M" g-boxes, can anyone think of another box that would work behind said motor? :?
Post Posted: Wed Sep 05, 2012 11:05 pm
Not off the shelf.
But a vit 5sp or AW4 would be a drastic improvement over the jimny box.
Unfortunately you will be pioneering this conversion, as I am yet to see evidence of it having been done.
Post Posted: Thu Sep 06, 2012 11:06 pm
Gave Suzistore a call today to see what they thought...they are going to chuck a vit 5spd next to a "M" donk for me to see what needs to done :)
Vehicle: 1985 lwb sierra UTE
Post Posted: Thu Sep 06, 2012 11:47 pm
That's some pretty awesome service :shocked:
Post Posted: Fri Sep 07, 2012 12:09 am
For the ute??
Post Posted: Fri Sep 07, 2012 12:31 am
Which M- motor do you have?
IMO, you'd be better off fitting a J20 with vit 5sp.
Post Posted: Fri Sep 07, 2012 1:03 am
Work out a way to use the Gen3 2dr GV M16a vvt box. They are meant to be long though, Maybe can be shortened somehow. Bit rare also :roll: :lol:
Post Posted: Fri Sep 07, 2012 9:59 am
None at the moment, but if running the vit 5spd behind one is possible, i will be looking at using either a m16a non-vvt or m18a VVT.
I have never been in a J20 powered vit so can't comment on that engine, but i do like the "m" series motor's... May even be a good replacement for the vit 1.6 motor's once they are all fuked??? :lol:
Post Posted: Fri Sep 07, 2012 10:58 am
Well a J20 powered vit is marginally better to drive than a G16B powered vit. But with another 25kw, 30+Nm, and lower peaker torque rpm, a J20 in a sierra is a much more exciting prospect. Tanshi's was VERY quick apparently.
The M18a (92 kW at 5,500 rpm and 170 N·m at 4,200 rpm) is almost the same output as the J20a ( 97 kW at 6300 rpm and 166 N.m at 2,900 rpm ), but with the added hassle of having to make adaptors.
Post Posted: Fri Sep 07, 2012 12:05 pm
monley wrote:
I have never been in a J20 powered vit so can't comment on that engine,:
Pop over some time through the week :wink: , i get my car back monday arvo
Post Posted: Fri Sep 07, 2012 2:46 pm
Thanks for the info Pete, but much like the vit 1.6's, J20 donks are not easy to find over this way (yet to see one for sale).... :?
Doing anything this afternoon? :D
Post Posted: Fri Sep 07, 2012 2:47 pm
It's Friday.
Post Posted: Fri Sep 07, 2012 2:50 pm
:oops: I was skim reading on my phone and thought he said "this week" :oops:
Post Posted: Fri Sep 07, 2012 2:56 pm
Fair enough.
They don't come up for sale very often over here either, But I wouldn't say they are hard to find. I'm suprised the M18a is seen as more attainable though :?
Post Posted: Fri Sep 07, 2012 2:58 pm
Fair enough.
Yeh, your maybe right there, but there is still a heap of m15a's/16's out there...
Post Posted: Fri Sep 07, 2012 3:07 pm
True dat!
Maybe a blown M15? would do better than a stock M18 or J20. M15's are cheap as chips, readily available, and make good power out of the box, so you could get it up and running NA, then throw a hairdryer at it later if need be.
I'm keen to see how the adaptor works.
Also, I spoke to Steve from Killa custom cables, and he reckons he could make a plug and play loom for the M15a, so thats a bonus. :wink:
Post Posted: Fri Sep 07, 2012 3:15 pm
True dat!
Armsup
Should hopefully hear something back from suzistore next week or so about how it will work :)
If i go down the m15 path, i will go non-vvt (no key coding shit) then buy a spare donk to build up and do as you say and chuck a blower on it :D
How much power are the vit 5spd's good for?
Wonder how much longer a "M" motor is than a 1.6? :?
Post Posted: Fri Sep 07, 2012 3:20 pm
monley wrote:
True dat!
Armsup
I think you could safely run 120kw through the vit 5sp. Maybe 150 if you have some mechanical sypathy. The AW4 will take 150kw with a decent cooler and correct transfer gearing.
As for length, I'm not sure there would be much difference between an M15 and a G16. Maybe 50mm?
Vehicle: Suzuki Jimny 2010
Post Posted: Fri Sep 07, 2012 7:58 pm
monley wrote:
True dat!
Armsup
I did read somewhere, that this years or last years swift was running an m16 that had a 100kw and a 6 speed box.... never looked into ratios, and they're probably going to be a fair bit harder to find aswell :(
Post Posted: Fri Sep 07, 2012 7:59 pm
And FWD?
Post Posted: Fri Sep 07, 2012 8:01 pm
How do you figure on using a FWD transaxle gearbox for a RWD vehicle?
Post Posted: Fri Sep 07, 2012 8:05 pm
Minor set back lol.... Isn't the M18 a FWD??
Post Posted: Fri Sep 07, 2012 8:10 pm
it bolts to a RWD 5 speed gearbox + transfer :wink:
Post Posted: Fri Sep 07, 2012 8:14 pm
yeah thats what I meant.... Didn't really think about the gearbox side of things, but surely the motor would be usable...
I'm only half stupid... I swear :p
Post Posted: Fri Sep 07, 2012 8:17 pm
The M16 swift sport motor is not the best option for a 4wd. It makes all its power and touque WAY up in the rev range. An M15 or M18 would be better.
Post Posted: Fri Sep 07, 2012 8:39 pm
If a j20 fits then a j24 would fit. They go hard :D
Post Posted: Fri Sep 07, 2012 9:59 pm
Agreed. VERY nice motor.
I missed out on a complete (water damaged) GV3 wagon at auction last year. Was completely unharmed, save for some interior water damage. Went for $4k :shocked:
The bloke who bought it said that he changed all the oils and it ran perfectly. :x
Nobody has been able to confirm if they share the same bellhousing pattern as the J20 though, despite the shared engine prefix. :?
Post Posted: Fri Sep 07, 2012 10:03 pm
And overseas markets got a J24B turbo putting out upto 225kw :shocked:
Post Posted: Fri Sep 07, 2012 10:19 pm
Link? 8)
Post Posted: Fri Sep 07, 2012 10:28 pm
Link? 8)
Just Wiki. It may have never gone past concept stage. The concept was called the Kizashi Apex. Although a road going version would have been re-named.
EDIT: Suzuki kizashi turbo. 179kw ( up from 131)
http://www.suzuki.com.au/community/news/kizashi-turbo-debuts
Users browsing this forum: Google [Bot] and 67 guests
