[ 6 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
andrewa
Joined: Fri Aug 25, 2006 11:30 pm Posts: 278 Location: bundamba
 Posted: Tue Dec 16, 2008 12:14 am |
hi guys. i want to flush my zooks cooling system over christmas & was wondering the best way to go about doing the job.
andrew.
Scrawny
Joined: Tue Jan 29, 2008 10:30 pm Posts: 10528 Location: Brissie
 Posted: Tue Dec 16, 2008 12:30 am |
The easiest way I've found is to drop a heater hose off the firewall, put the heater on hot, then stick the garden hose in to the heater hose. Make sure the cap and drain bung are out the radiator too. Keep it in there till it runs clear.
Just remember when refilling with coolant that the block will be full of fresh water. Also be careful when pulling the heater hoses off, the tube they attach to crushes very easily as it's only copper
Damo
Joined: Sat Jul 22, 2006 11:30 pm Posts: 4661 Location: Brisbane
 Posted: Tue Dec 16, 2008 2:47 am |
It would also be an idea to put some flush through it. I got some really nasty smelling stuff from a radiator place. Supercheap etc would have something too.
_________________ SJ50.4.LYF
andrewa
 Posted: Wed Dec 17, 2008 2:14 am |
the plan was to drain system first then put flush through system & refill with pre-mix coolant. how do you empty excess water from system
cheers.
Scrawny
 Posted: Wed Dec 17, 2008 2:16 am |
Not easily, I usually just use concentrate coolant and then top up with mixed if needed
royce
 Posted: Wed Dec 17, 2008 2:28 am |
blow it out with air
[ 6 posts ] |
Users browsing this forum: No registered users and 287 guests
