It is currently Tue Nov 03, 2026 9:18 am
Vehicle: abc
Post Posted: Sat Sep 15, 2012 7:43 pm
Hey guys,
Having the issue with sourcing a idler tensioner pulley for the M13A
Only one i have been able to source is http://www.suzistore.com.au/shopexd.asp?id=1897
For $250 thats crazy!!! Autobarn, Repco, Supercheap etc... have no idea what i am on about either :S
Reason for trying to find one is, it is destroying the P/S A/C belt and has visible signs of due replacement.
Has anyone attempted to even replace *just* the bearing?
On i think http://www.suzuki-forums.com , a few people spoke about doing this same replacement on there late model GV's? pictures looked as though it was the exact setup as our M13A's??? :S
ANY info is highly appreciated!
Post Posted: Sat Sep 15, 2012 9:28 pm
Pull it off, From memory it is a bearing inside that could be bought at a bearing place. Im using one but on a different motor.
How big does the tensioner look? I could be getting mixed up with another baleno one i have :oops:
Post Posted: Sun Sep 16, 2012 8:07 am
isnt it similar to a Barina one or some hatchback like that? vaugely remember this coming up before....
MY BUILD THREAD HERE!!!!!
Post Posted: Sun Sep 16, 2012 9:31 am
I agree pull it off. and take it to a bearing place will save you heaps
pretty sure its only 2 bolts that hold it on.
Vehicle: abc
Post Posted: Sun Sep 16, 2012 10:35 am
Post Posted: Sun Sep 16, 2012 10:38 am
oh yeah im mixed up.
I have a good one here i think, if you want. will just try it now
Vehicle: abc
Post Posted: Sun Sep 16, 2012 10:39 am
It should be the exact same as your -
M13A - Liana, Jimny, Ignis...
M15A - Ignis, Swift, SX4, Cruze...
M16A - SX4, Liana, Swift Sport, GV's...
M18A - Liana...
Vehicle: abc
Post Posted: Sun Sep 16, 2012 10:41 am
Oh, Cheers! Thankyou!
Even if it is a bad one, ill take it to get a new bearing installed ;)
Post Posted: Sun Sep 16, 2012 11:50 am
M18A - Liana...
Oh, yeah of course those too.. but i specifically remember someone mentioning a NON-suzuki part (Read: Not $$$$). Ah well bugger it... itll come to me eventually. But yeah, as the boys have said. just press out the bearing and get a replacement... piss.
Post Posted: Sun Sep 16, 2012 4:20 pm
Ok the one i have here is the same. 88mm diameter. Bearing runs smooth but the surface where the belt was running, there is a groove, the width of the belt, like the rubber belt has worn in
It is all pressed together. 1 piece. You could maybe try and pry one of the sides off, but could be risky.
Vehicle: abc
Post Posted: Sun Sep 16, 2012 6:28 pm
My work has a press so, i may be able to press the old, press the new bearing on?
Now, down to business, How much :roll:
Post Posted: Sun Sep 16, 2012 7:05 pm
Yeah maybe, It really doesnt look like it would like to come apart.
Looks like a unique component, thats why they can charge so much.
pm'd.
Users browsing this forum: No registered users and 89 guests
