http://auszookers.com/forum/
30" tyres hitting chasi on vit how to restrict steering?
http://auszookers.com/forum/viewtopic.php?f=5&t=35773
Author:  Charlie Brown [ Mon Sep 17, 2012 8:25 am ]
Post subject:  30" tyres hitting chasi on vit how to restrict steering?
Just wondering how I can restrict my steering so my 30".tyres stop scrubbing up my chasi?
Thanks again guys your help is greatly appreciated! :D
Author:  Charlie Brown [ Mon Sep 17, 2012 8:34 am ]
Post subject:  Re: 30" tyres hitting chasi on vit how to restrict steering?
Btw I don't even mind if u just link me to another thread if there's a good one on this :P
Author:  alien [ Mon Sep 17, 2012 9:32 am ]
buy bigger offset rims.
Author:  shep [ Mon Sep 17, 2012 9:42 am ]
I had 33x12.5 tyres on a vit and they only scrubbed a little on the guard. Rims were 15x8 -13 offset
Author:  atari4x4 [ Mon Sep 17, 2012 9:51 am ]
pretty sure that wasn't the question :roll:
that vitara was pretty modified before you got it, old mate had done a heap of clearancing to get 32's to fit.
Mr Charles Brown,
You can adjust the steering stops by the steering box, one is on the pitman arm & the other is on the chassis located in the right hand front corner of the vehicle, both are visible from underneath.
Thanks
Mr 4x4
Author:  Charlie Brown [ Mon Sep 17, 2012 10:27 am ]
Yeah I would like some off set rims...got some cheap ones? :P
Thanks Atari that was what I was looking for! Is there a thread showing how to do this? Thanks
Author:  atari4x4 [ Mon Sep 17, 2012 10:37 am ]
nah no thread, just turn the wheel to the left so it's just off the chassis rail & look up at the steering box & wind the bolt out til it's touching the stop, then do the same for the RHS
Author:  Charlie Brown [ Mon Sep 17, 2012 10:39 am ]
Okey dokey ill give it a go when I get home thanks again for your help mate!
Author:  got_bar_work [ Mon Sep 17, 2012 10:40 am ]
U might need longer bolts or just weld a nut on the end of the bolt
Author:  Charlie Brown [ Mon Sep 17, 2012 2:45 pm ]
Ok so I got home and had a look and are these the bolts you are talking about just making them tighter (move into the middle of the car) to lessen the maximum turn?
thanks =D
Author:  atari4x4 [ Mon Sep 17, 2012 2:50 pm ]
Nope, they are tie rods. Look at the pitman arm that is attached to the steering box.
Author:  Charlie Brown [ Mon Sep 17, 2012 3:23 pm ]
When u say steering box do u mean the power steering cos I don't have it :P sorry I'm a noob
Author:  zukmeista [ Mon Sep 17, 2012 3:28 pm ]
No, if you look at the front of the chassis rail on the driver's side you will see a funny looking thing with a shaft going into the top of it and an arm on the bottom of it. This is the steering box, the arm on the bottom is the piman arm.
Author:  want33s [ Mon Sep 17, 2012 3:57 pm ]
Steering box...
Author:  atari4x4 [ Mon Sep 17, 2012 3:59 pm ]
jas beat me... :oops:
stolen from lowrange's website
bottom right is the pitman arm & one of the steering stops, the other is chassis mounted
Author:  Charlie Brown [ Mon Sep 17, 2012 7:48 pm ]
Okey dokey thanks guys, found it (well I'm 99% sure =P ) attached to the chasi, is this the nut you tighten here in these pictures? (sorry had to use a torch under the car so they are crappy quality)
Author:  shandy92 [ Mon Sep 17, 2012 8:16 pm ]
yes! undo the nut, wind the bolt out. tighten the nut.
Author:  Charlie Brown [ Mon Sep 17, 2012 8:29 pm ]
ok so winding the bolt out will lessen the amount the wheels can turn? =P thanks!!
Author:  atari4x4 [ Mon Sep 17, 2012 8:35 pm ]
bingo Armsup
Author:  Charlie Brown [ Mon Sep 17, 2012 8:53 pm ]
im on a roll !!! :P thanks guys I'll try getting onto it tomorrow :D
