It is currently Mon Oct 19, 2026 2:21 am
Post Posted: Wed Sep 19, 2012 9:11 pm
Can you do a rear main seal in a suzuki sierra g13a motor if you pull the gear box out of the car on a hoist. Ijust wanted to know .Or do you have to pull the motor to bits .
Post Posted: Wed Sep 19, 2012 9:18 pm
you can do one by pulling the gearbox on a hoist. all you have to do is remove the clutch and flywheel aswell.
Sierra, 32's, Airlocked, 6.5'd, hopefully ruf soon
Post Posted: Wed Sep 19, 2012 9:21 pm
thanks Aaron
Post Posted: Thu Sep 20, 2012 5:07 pm
While your in there have a look at your clutch condition. If its shagged get your flywheel machined aswell as a new clutch kit. In the kit you should get new spigot bearing and throwout bearing aswell!
Post Posted: Wed Sep 26, 2012 10:48 am
Hi guys,
any tips or guide before i start to try to replace the rear main seal? I am a beginner and need some pointer like where to even start....
Post Posted: Wed Sep 26, 2012 1:53 pm
If you have to ask questions on doing a rear main I'd suggest you get help of a mechanic. That way you get a warranty with all work done. Otherwise best bang for buck go to supercheap and buy a Sierra manual, a trolley jack, couple of axle stands, a good socket and spanner set, a good breaker bar. Study, study, study the manual. It's actually a really easy job for someone who is mechanically mInded. But that book gives u step by step procedure and worth every cent you pay. Keep it under your seat so if you ever break down just have a skim through the manual!
Post Posted: Wed Sep 26, 2012 2:36 pm
i just went to get the tools and a pair of jack stands. cant find the manual :(
Can i remove my transmission and replace the seals directly?
Vehicle: Ducati Monster
Post Posted: Wed Sep 26, 2012 3:00 pm
heres a link to an online manual mate
http://www.suzukiinfo.com/sierra/suzukiinfo-sj413fsm.pdf
hope it helps
Post Posted: Wed Sep 26, 2012 3:27 pm
Thanks for that!
hope it helps
Post Posted: Wed Sep 26, 2012 3:32 pm
no probs 8)
Post Posted: Wed Sep 26, 2012 4:02 pm
Just make sure you get someone else under there with ya. I can quite easily pull out a box but putting it back in normally takes 2 people. Once she is ready to come free. Remove the extractors or exhaust manifold of the engine.Leave one bolt through the bellhousing. Lightly jack the front of the engine up with a block of timber under ur sump. This aids in removal of the box. Get ur 2nd person to look in the engine bay for any taught wires/hoses etc.
Being a beginner I strongly suggest you get someone to help you just manipulating the box out and in. Also a 2nd person makes a great tool chucker. Nothing worse when a tool is out of reach. The 1st thing you should do when under the car is make sure it's chocked very well. Chock every wheel if you want!!
Post Posted: Wed Sep 26, 2012 4:18 pm
thanks ahead for the tips
Post Posted: Wed Sep 26, 2012 4:50 pm
No worries. Good to see your taking in everybody's advice. If you need anymore info feEl free to inbox me!
Vehicle: '94 suzuki maruti
Post Posted: Thu Sep 27, 2012 5:26 pm
i don't have access to a hoist so its a little different, but i found it waaay easier to just remove the whole engine/box in one hit. more to do with laziness as i didnt want to have to lift the box up under the car afterwards. not much good if you dont have an engine crane though... but it does allow a lot more access to it all.
Post Posted: Thu Sep 27, 2012 10:27 pm
x2 on the second person, yeah 1 is enough to get the box out (i did my vit on the ground lifting the gearbox and transfer out, a sierra being divorced would be much lighter. I did get a mate to help lift it all back in
Users browsing this forum: Google Adsense [Bot] and 439 guests
