It is currently Thu Oct 22, 2026 9:09 am
Vehicle: LJ50 LC10W
Post Posted: Mon Sep 24, 2012 6:58 pm
I am planning on making some tripple carb kits, anyone interested?
Post Posted: Mon Sep 24, 2012 7:03 pm
What to fit? Not much point bolting 3 carbs to a g13
Post Posted: Tue Sep 25, 2012 4:59 am
:roll: Take one look at his username. What do you think :thefinger:
Post Posted: Tue Sep 25, 2012 9:10 am
Yep interested!
Vehicle: LJ50 LC10W
Post Posted: Tue Sep 25, 2012 3:22 pm
i have a few sets of the factory tripples of the fronte LC10W but i plan to make new maniflds with larger carbys
Vehicle: LJ20 LJ50
Post Posted: Tue Sep 25, 2012 3:26 pm
Do you have any duals????
Camels have nice toes
Post Posted: Tue Sep 25, 2012 3:30 pm
IM assuming they will be setup to work the oil pump as the standard one is?
Post Posted: Tue Sep 25, 2012 10:35 pm
Triple injected throttle bodies!! :D
Vehicle: LJ50V, SJ70
Post Posted: Tue Sep 25, 2012 11:13 pm
I'll take an old Manifold if you're not going to use it, and interested in a factory Manifold + 3 Carb set up if you have one spare.
Post Posted: Wed Sep 26, 2012 8:22 am
i would be interested in a set of standard too honestly.
Post Posted: Wed Sep 26, 2012 4:13 pm
A Mate of mine used to have a SC100 in the 80's. It was the F10A version of the rear-engined Fronte, and I was lucky enough to get the Service Manual and Parts Manual off him when he wrote it off. He also had a Parts Manual for the LC20. The LC20 was also a rear-engined 3 cyl 2 stroke, but it didn't have triple carbs, it had one big downdraught like the LJ50.
Can you show us some pics of your LC10W's engine? It's basically an LJ50 3 cyl, but with an odd sandwich head and mounted transversly at the rear.
Vehicle: LJ50 LC10W
Post Posted: Wed Sep 26, 2012 4:24 pm
i've got tripple throttle body of a triumph, i am going to use a daihatsu ecu (got stacks of em) which requires a electronic dizzy to trigger it.
Post Posted: Wed Sep 26, 2012 4:28 pm
interested. I also have a triumph triple 900 throttle body, was looking at mega squirting it. but looking forward to hearing more about your setup
Vehicle: LJ50 LC10W
Post Posted: Wed Sep 26, 2012 7:26 pm
triumph throttle body a little wide for lj50, i am making a cad drawing of a more suitable throttle body. probably 38mm butterfly
Post Posted: Wed Sep 26, 2012 7:35 pm
Thread title edited for correct spelling so it can be found in a search.
Post Posted: Wed Sep 26, 2012 7:46 pm
Sounds quite interesting :wink: . Wonder how far the fuelling and timing will be off. Which Daihatsu ECUs you thinking of using?
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 151 guests
