Vehicle: Suzuki jb43 jimny
Posted: Wed Sep 26, 2012 10:31 pm
Howdy I have a swb Suzuki vitara, I'm looking at fitting recovery hooks front and rear as I only have tie down points, I'm woundering is it safe to attach theses though the chassi rails with the high tensile bolts or if there's a better way, any help would be great
Joined: Sun Nov 20, 2011 8:05 am Posts: 82 Location: Brisbane AU, Queenstown NZ
Vehicle: SWB Vitara
Posted: Wed Sep 26, 2012 11:26 pm
If you have a rear tow bar, usually the recovery points can be bolted to that.
On the front, bits4vits do a tidy looking recovery bar that is quite easy to replicate. It is essentially a threaded bar that runs through the front tubular cross member.
I am sure there are other options,we currently have hooks bolted into the bottom of the front chassis rails, going into tapped flat bar. Easier described with a photo though...
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 73 guests
