It is currently Mon Oct 19, 2026 1:35 am
Post Posted: Fri Sep 28, 2012 6:03 pm
hey all, thanks in advance for reading this,
my sierra just played up pretty bad, it has a 1.6mpfi in it, i was just driving down the highway when it started losing power and struggled to even keep momentum, after a few minutes of this it came good, well good enough to drive at 100kph, but it missed a few beats and was down on power, i got it to my mums where it played up again and just stalled, i left it for about 5mins and it started and idled fine again. i think this is a fuel pump, if anyone else knows more about the issue im all ears.
does anyone have a spare fuel pump or be able to help me out at all?
Post Posted: Fri Sep 28, 2012 6:06 pm
Who did the conversion, and what fuel pump was used?
Post Posted: Fri Sep 28, 2012 6:07 pm
i did, and the original fuel pump was used that came with the vitara, this was well over a year ago
Post Posted: Fri Sep 28, 2012 6:26 pm
So what fuel tank are you using?
Is your fuel filter blocked?
Are you getting fuel at the rail? Return also?
Post Posted: Fri Sep 28, 2012 6:37 pm
Yes as fat zook said. Disconnect the fuel in line to the injector rail and get someone to hit the ignition a few times and see if fuel comes out. You could even disconnect it after the filter providing the pump is before the filter. If no fuel comes through you have a blockage. My zook did this with the g16b. I have 2 pumps. My prepump had a micron filter before it and it was blocked up!
Post Posted: Fri Sep 28, 2012 7:10 pm
hey guys thanks again for your assistance.
i disconnected the fuel line after the fuel filter and before the filter, it was the same both times, but i remember last year that when i had a line disconnected that fuel shot out with some serious force,
just then it came out steady, but not with the high pressure i was expecting
Post Posted: Fri Sep 28, 2012 7:25 pm
oh and im using the standard coily tank i had
Post Posted: Fri Sep 28, 2012 7:39 pm
Yeah the fuel should fire across the room.
On the end of the fuel pump, there is a little filter bag. Its possible that this is blocked/ caked with shit.
Might be worth having a look there if you thing the fuel pressure is a bit low.
Post Posted: Fri Sep 28, 2012 7:54 pm
yea i'll do that early in the morning, if its all clean and it is the pump, i'll have to give suzi sport a buzz, hopefully they have one, i may just go and buy this mazda 6 diesel wagon i've been eyeing off too.
thanks again Pete
Post Posted: Fri Sep 28, 2012 8:02 pm
No worries.
If you have access to a fuel pressure guage it will confirm your suspisions.
Post Posted: Sat Sep 29, 2012 5:15 pm
just my luck, bought a new fuel pump this morning, only got home this arvo, turns out they sold me the wrong pump..have to wait till tuesday now, not fun at all.
Users browsing this forum: No registered users and 271 guests
