http://auszookers.com/forum/
help in south brisbane area
http://auszookers.com/forum/viewtopic.php?f=5&t=36026
Author:  mondo [ Fri Sep 28, 2012 6:03 pm ]
Post subject:  help in south brisbane area
hey all, thanks in advance for reading this,
my sierra just played up pretty bad, it has a 1.6mpfi in it, i was just driving down the highway when it started losing power and struggled to even keep momentum, after a few minutes of this it came good, well good enough to drive at 100kph, but it missed a few beats and was down on power, i got it to my mums where it played up again and just stalled, i left it for about 5mins and it started and idled fine again. i think this is a fuel pump, if anyone else knows more about the issue im all ears.
does anyone have a spare fuel pump or be able to help me out at all?
Author:  Fatzook [ Fri Sep 28, 2012 6:06 pm ]
Post subject:  Re: help in south brisbane area
Who did the conversion, and what fuel pump was used?
Author:  mondo [ Fri Sep 28, 2012 6:07 pm ]
i did, and the original fuel pump was used that came with the vitara, this was well over a year ago
Author:  Fatzook [ Fri Sep 28, 2012 6:26 pm ]
So what fuel tank are you using?
Is your fuel filter blocked?
Are you getting fuel at the rail? Return also?
Author:  reeceh [ Fri Sep 28, 2012 6:37 pm ]
Yes as fat zook said. Disconnect the fuel in line to the injector rail and get someone to hit the ignition a few times and see if fuel comes out. You could even disconnect it after the filter providing the pump is before the filter. If no fuel comes through you have a blockage. My zook did this with the g16b. I have 2 pumps. My prepump had a micron filter before it and it was blocked up!
Author:  mondo [ Fri Sep 28, 2012 7:10 pm ]
hey guys thanks again for your assistance.
i disconnected the fuel line after the fuel filter and before the filter, it was the same both times, but i remember last year that when i had a line disconnected that fuel shot out with some serious force,
just then it came out steady, but not with the high pressure i was expecting
Author:  mondo [ Fri Sep 28, 2012 7:25 pm ]
oh and im using the standard coily tank i had
Author:  Fatzook [ Fri Sep 28, 2012 7:39 pm ]
Yeah the fuel should fire across the room.
On the end of the fuel pump, there is a little filter bag. Its possible that this is blocked/ caked with shit.
Might be worth having a look there if you thing the fuel pressure is a bit low.
Author:  mondo [ Fri Sep 28, 2012 7:54 pm ]
yea i'll do that early in the morning, if its all clean and it is the pump, i'll have to give suzi sport a buzz, hopefully they have one, i may just go and buy this mazda 6 diesel wagon i've been eyeing off too.
thanks again Pete
Author:  Fatzook [ Fri Sep 28, 2012 8:02 pm ]
No worries.
If you have access to a fuel pressure guage it will confirm your suspisions.
Author:  mondo [ Sat Sep 29, 2012 5:15 pm ]
just my luck, bought a new fuel pump this morning, only got home this arvo, turns out they sold me the wrong pump..have to wait till tuesday now, not fun at all.
