http://auszookers.com/forum/
efs 65 mm springs
http://auszookers.com/forum/viewtopic.php?f=5&t=36030
Author:  bulladean_ [ Fri Sep 28, 2012 7:14 pm ]
Post subject:  efs 65 mm springs
hey guys i have purchased some of what i have been told are a 65 mm lifted spring by efs. But it doesnt quite seem right. The guy had no idea when he was ordering them and stuffed up just about everything. I was wondering if anyone has them and can tell me what it has writin on them.
Author:  Gwagensteve [ Fri Sep 28, 2012 7:32 pm ]
Post subject:  Re: efs 65 mm springs
Dank should be able to help
Author:  Macca52 [ Fri Sep 28, 2012 7:58 pm ]
My EFS springs sourced from onlineautoparts have SUZ03E on the ffronts and SUZ05E on the rears. They do not make them handed for right and left. Hope this helps. P.S. Mine also had other numbers printed on the other end of the springs but EFS had no idea what they represented. thought they may just have been a middle mans stock no's.
I hope this helps.
Macca
Author:  bulladean_ [ Fri Sep 28, 2012 8:08 pm ]
yeah thats what mine have. Thanks heaps man. Back spring pack is pretty big.
Author:  reeceh [ Fri Sep 28, 2012 8:13 pm ]
I have efs 65 mm lift springs aswell. I called dank to confirm what side what lead? He said look for the bigger arch. I couldn't see it however I have big drivers sag so I should swap mr rear springs from side to side!
Author:  Macca52 [ Fri Sep 28, 2012 9:04 pm ]
I fitted mine and had nearly 50mm lean on right. Swapped both springs right to left and car sat level for first day. After only one trip is developing r/h lean again already. Haven't measured yet but appears to be at least 25mm. Am going to give up - am getting pissed off!!
Author:  Macca52 [ Fri Sep 28, 2012 9:27 pm ]
But will admit car has never felt so good, much more comfortable off road than with bluepack springs.
