It is currently Mon Oct 19, 2026 12:47 am
Vehicle: Coily "Ute"
Post Posted: Fri Sep 28, 2012 8:45 pm
Has any one had any experience with radiator stop leak?
I know it's only a band aid fix but how long is expected to last?
Post Posted: Fri Sep 28, 2012 8:47 pm
Silverseal is my preferred brand. I have seen it almost permanently fix radiator and block leaks.
Post Posted: Fri Sep 28, 2012 11:02 pm
ive cracked an egg in a radiator before to stop leaks... and pepper , all of this is not permanent.
Vehicle: 89 SWB zuke
Post Posted: Sat Sep 29, 2012 12:04 am
8O Did it work?? I assume you remove water first and let dry?
You would preety much be bush mechanic god after showing that one off, on the the trail.
Ahh should also say YES I have had experience with it. . . . . taking a water pump off and seen the consequences. It was built up in all cavities that were not in the "high flow" areas of the water system. Had the consistency of sand (probably isn’t as hard though). Was a G16B from wreckers, radiator was full so obviously worked :D
Post Posted: Sat Sep 29, 2012 6:41 am
If it is just a leaking radiator I would get it repaired rather then put any of the stop leak stuff in a good motor.
Post Posted: Sat Sep 29, 2012 8:04 pm
the egg trick works. Ive done it before. You just crack a raw egg into the rad and fill up with water. Put cap on but dont lock it down tight . Let it sit loose for a while. As egg circulates it is pushed out where leak is and clogs it up. a good tempaory fix but isnt permanent.
Pepper works very similar.
Post Posted: Sat Sep 29, 2012 8:09 pm
Thats the plan shep. I just needed the car this weekend and it wasnt a serious leak.
Post Posted: Sat Sep 29, 2012 8:33 pm
Have used pepper a few times with good success.
Post Posted: Sun Sep 30, 2012 5:43 am
x2. I use this and I have a spare tube in every car I own.
Put some in my Drover's radiator about 4 years ago when it had a slight leak and its still going today.
Post Posted: Mon Oct 01, 2012 4:15 am
my 12mth old plastic tank ebay radiator sprung a leak yesterday
whacked in half a cup of black pepper and stopped it , this works well once it all
heats up and can last a long time if the leak is small but really it's a stopgap
untill you replace the radiator which i'll do this comming week with an all metal
radiator
Vehicle: jimny 3"jb lift 235/75/15
Post Posted: Mon Oct 01, 2012 9:08 am
seal up
Users browsing this forum: No registered users and 284 guests
